I am going to continue this thread here which I should've applied it to in the first place. It is my own GB sheesh.
the WIP was originally started in the Aircraft Groups. I will just start where I left off.
With the halves mated and most of the cockpit completed, next is to work on some exterior details.
1st a the LH side insert panel is attached to the LH rear 1/4 of the fuselage.
Next the front and rear seats have the PE belts applied and set aside to set.
The upper intake is then attached at the top section of the engine compartment.
Then the intake upper panel is prepped trimmed and installed above the main engine intakes.
1. Nasty gap will be filled, not too difficult to fix
The LH/RH intakes are installed.
Next up some lower details, install the seats,
More to follow...
