Car Door Incident - Hasegawa 1/48 Hawker Typhoon
Started by Editor · 88 · 2 weeks ago
    Editor said 1 year, 1 month ago:
    Finally today! Gluing of wing halves...
    ...then, affixing the wing to fuselage, and then the wing root joint. Every element on this picture has a role in the latter!
    John vd Biggelaar said 1 year, 1 month ago:
    Now that is some serious balancing, Martin @editor
    Looks perfectly straight.
    Tom Cleaver said 1 year, 1 month ago:
    This is looking very good, Martin @editor. You're setting a new standard for this kit.
    Spiros Pendedekas said 1 year, 1 month ago:
    Great progress, my friend @editor!
    Thanks for your continued encouragement, @johnb and @fiveten
    Pedro L. Rocha said 1 year, 1 month ago:
    Humm, I see that I need some new set of skills to get those wings in shape when I build mine 😉
    Very nice progress Martin!
    @tcinla. Happy to hear that! A known law of modeling says that before I'm finished, someone's going to give out a superior new-tool kit of the same lol
    Editor said 1 month ago:
    Well, it's been a year since the last update on my Typhoon! I'll be honest and say that the project ground to a halt when I discovered there's a problem with the kit's armament.
    There were two variants of the 20mm cannon on the Typhoon a "naked" early type, similar in appearance to the same armament on the Hurricane IIc, and a shrouded later type. Both were represented on a car-door Typhoon, but for my specimen I needed the naked type.
    Then I discovered that the kit's rendition of the same is rather... puny. Short and inaccurate.
    The cannon barrels are much simplified, and the fixed part (the shroud), which should be different on the "naked gun" version, is simply a cut-off rear half of the shrouded cannon, which doesn't look the part. So what to do?
    My first attempt had been scratchbuilding new cannon barrels from brass tube and lead wire, and sanding down the shrouds to a more tapered form. This looked better, but still not very much like the real thing.
    Unhappy with the result, I kept looking for alternatives. Fortunately, there's one great source for all 1/48 cannon needs - Master Model of Poland, who offer these good-looking metal replacements for the early Typhoon:
    After obtaining the Master Model set (a few weeks' wait), I spent some time deliberating on how to integrate the metal parts into the wing without damaging the already refined surface detail. (This is the exact part that took so much time :). With the massive shroud at the end of each cannon barrel, the operation appeared complex. Some massive holes were required in the wings, followed by precise alignment, and the circular "sockets" in the wing leading edge would either need to survive the surgery or be replaced by the photoetched parts.
    So here's how I've done this. I measured the outer diameter of the Master shrouds to be 3.8mm. I serched up and ordered a drill bit of exactly that diameter in an specialist automotive supply store (another week's wait). Then, I sawed off the existing cannon at the right angle:, which gave me a 3.8mm cross-section:
    I then marked the center of each cannon and caaarefully drilled it out, starting with smaller-diameter drills and working to progressively larger ones ending up with the said 3.8mm bit. Holding the wing together was necessary to avoid splitting the leading edge seam. With four cannons to drill out, it was only partially successful!
    Anyway, this gave me a promisingly clean and aligned opening into which the metal parts test-fitted rather neatly..
    Finally, I glued everything in place, using long-setting epoxy glue in the bottom of the openings for strength, and UV-glue in the front for microfilling and to facilitate alignment. Phew! Done!
    I'm happy with the result. The finished cannon look very convincing and if I may say so, make the entire model appear more... manly. What's not to like. Hopefully, this brings the project back on track again!
    To be continued...
    Spiros Pendedekas said 1 month ago:
    These improved canons look absolutely stunning, my friend @editor! What a departure from the kit stock ones! Looking forward to your next steps!
    John vd Biggelaar said 1 month ago:
    Those cannons are amazing, Martin @editor
    Looking so much better than the original ones.
    A wise decision to have them replaced.
    Pedro L. Rocha said 4 weeks, 1 day ago:
    Glad to see you resume work on this beauty Martin.
    Those metal parts look terrific and perfectly assembled to the plastic, a very pristine workmanship.
    Also your WIP gives me a goods heads up about the kit parts. Luckily I still have some resin cannons (spares from my Hurricane) that may be the same kind the Tiffie had
