Classic Airframes 1/48 Brewster F2A-1 Buffalo, VF-3 "Felix Cat"
Started by Reinhard Spreitzhofer · 53 · 1 year ago
    Reinhard Spreitzhofer said 1 year, 5 months ago:
    Let´s see how this turns out, definitely more work than the Tamiya kit.
    upper and lower wing halves glued together, copckpit floor and some interior parts added
    started to add the sidewall instruments, partially a bit of a guessing game, but well, a typical shortrun kit
    engine is missing some detail, adding pushrods with plastic rods
    slow but steady progress
    as usual with shortrun kits, everything needs to be dry-fitted, a lot of cutting, sanding and filling
    engine inserted
    Although my dad looked through different build threads, he didn´t look enough.
    The engine sits about 5mm to deep in the cowl. Thought about using a longer drive shaft for the prop but that looks still somehow off. So my dad cut off the nose along a panel line and installed the engine in a correct, more forward position. Well, let´s see how the re-join will turn out...
    Great entry and superb progress over the challenging CA kit, my friend @grimreaper!
    Coming along fine, Reinhard (@grimreaper). I have heard this kit can be a challenge, but I suspect it will be a lot more detailed than the Tamiya kit. What paint scheme are you planning for this one?
    slightly more detailed, yes
    gonna do a black section scheme like the box art, but not sure if it´s gonna be the section leader or one of the two wingmen
    For sure this one will turn out beautiful as well, Reinhard @grimreaper
    it has worked out ! it has a nose again
    also tailplane done
    The nose looks great, my friend @grimreaper!
    Nicely done, Reinhard @grimreaper
    Louis Gardner said 1 year, 5 months ago:
    Reinhard Spreitzhofer (@grimreaper)
    Your Dad is a very talented builder. I have always said you guys are a great team. I have this same kit in the stash, and have looked at it several times. However each time I put it back. It does look like a nice kit though. I will definitely keep this build journal in mind for when the time comes and I do tackle mine.
    Your Dad is well on his way to the paint shop soon. Have you guys picked out the paint scheme yet as far as the section leader or the wing men ?
    primed the whole thing
    gonna do most probably the section leader
    Looks nicely primed, my friend @grimreaper!
