Salt Method
Started by Jeff Bailey · 11 · 5 years ago
    Jeff Bailey said 6 years, 8 months ago:
    Hello. What is the "salt method" I hear about? Martin D. showed some great before and after photos, but I don't understand the whole procedure. What kind of salt? (table salt or crude salt for snow & ice removal, etc.) I assume it is done with acrylics but Martin did mention the Oilbrushers.
    Thanks in advance.
    Pedro L. Rocha said 6 years, 8 months ago:
    Hi Jeff, It’s a rather simple method actually. With the purpose of getting a chipped paint effect one needs to softly moisten the primer/aluminium painted surface and then losely apply kitchen salt. Some countries have a rather refined, small grainy salt while others tend for a much chunky salt grain. Either work fine, though the finer grain gets you smaller effects obviously.
    Then, after the salt and surface dries, move to the next paint coat process, and as soon as possible (but with paint already dry) use a old toothbrush, cottonswab or stiff brush, again moistened with water to scratch the areas where the salt was applied. Go easy with the water amount. Too much ruins it, too little gets the job too tedious. I used acrylic paint sealed with enamel varnish over the primer coat only. The second paint coat, again acrylic, had no varnish applied.
    Personally, I’ve not yet used this method because I have some “chipping effects” AM products that I feel very comfortable using so far, but did try over an old model a few years ago just to see if it works...and it does
    Hello Jeff. Jeff most of these techniques can be found on YouTube . Loads of modelling tips and reviews. Cheers buddy.
    Thanks for the explanation, Pedro!
    Thanks, Anthony!
    Dmitry Stropalov said 6 years, 8 months ago:
    Hi Jeff! I use this method with acrylic paints (actually with Gunze and Tamiya, but not with Vallejo-like paints). I was using it for my Hellcat and there are WIP pictures, covering the process. Just scroll to the bottom a little – http://imodeler.com/groups/group-build-d-day/forum/topic/d-day-build-148-hellcat-mk-i/?topic_page=2&num=15
    Panzer Machine said 6 years, 7 months ago:
    Hope this short movie tells everything to you Jeff 🙂
    Craig Abrahamson said 6 years, 7 months ago:
    Hi Jeff...I've never tried the "salt method" either, but I'll tell ya what DID work pretty well (at least for me). I sprayed the surface with aluminum, then applied the top coat. Then using low tack tape (in this case, 3M Blue tape), laid it over the surface and yanked it off. The top coat came off, revealing the aluminum undercoat. Just gotta use care so as not to take off too much of the main color (small pieces of tape). Good luck.
    Jeff Bailey said 6 years, 5 months ago:
    Thanks, Dmitry!
    Thanks, Craig. It seems to be a much simpler method than others I found.
    Julio Contreras Martínez said 5 years, 12 months ago:
    Hola Jeff...Es muy interesante y parece fácil de hacer.Lo probaré en el próximo vehículo que modele.
    Se aprende mucho con vosotros e iModeler. Gracias por todo esto.
