    Thanks my friend @johnb anc @gblair!
    Usually Hasegawa decals from more or less that era worked like my ones, meaning:
    • They take ages to detach from their backing paper (5 minutes or so). I think warm water helps. I dip them in the water for a 1-2 minutes, then take them out and patiently wait...
    • Once off the backing paper, they adhere well onto the model.
    • If containing "white" sections, Hasegawa, till recently, represented them as "ivory", which annoyed most modelers, no whites in my case, though 🙂 .
    • Typically theey endure well with time, especially if they are sealed together with the clear parts, as is (was?) the Hasegawa usual case.
    John, the engine looks very convincing indeed!
    capt. R said 3 years ago:
    @johnb engine are beautifull!
    @gblair, @lis, thanks for these kinds words.
    @fiveten, thanks for sharing this approach. Decalling will be after I have applied this 'difficult' striped scheme. This is what holds me back at the moment, more less afraid to get that paintwork started.
    I am sure you'll do a perfect painting job, my friend @johnb!
    Tom Cleaver said 3 years ago:
    You guys are getting really nice results, @fiveten and @johnb.
    I just saw 3D computer renderings for the new Eduard Zero. It's going to do to the Hasegawa Zero what their P-51D did to Tamiya's old eagle. Ditto their coming F4F, which won't have an FM-2 cockpit as the Tamiya F4F-4 does. And will be coming in F4F-3, F4F-4, FM-1 and FM-2 varieties.
    No put-down of the excellent modeling talent on display here, but I have to say these new kits from Eduard are finally delivering the model kits I wanted when I was comparing Aurora kits to photos of the real thing.
    Thanks my friend @tcinla!
    Yep, regarding the Eduard and Hasegawa Zeros, looks like "the enemy of good is better".
    Looking forward to their F4F, as well.
    Moving on...
    • Added engine, cowling, seat, stick, gunsight, headrest, rear wheel and hook cover (not all are shown)...
    • Added brake lines from stretched sprue...
    • The prop is ready too! Thanks for stopping by!
    Brake lines added...
    I used net available pics, depicting how the brake lines were routed, stretched sprue was used.
    Those brake lines are a great addition, Spiros @fiveten
    Your Zero looks amazing already.
    Thanks my friend @johnb!
    Michael Ezat said 3 years ago:
    Spiros , your Zeke comes better and better ! At the end must be great , good work !
    Thanks my friend Μιχάλη @faoromike!
    Main landing gear and rear wheel painted black, some touchups where black has been applied took place, as well...
    Looks great, Spiros @fiveten
    Almost time to get her on her feet.
    Typhoon vs Zero
    This morning I swapped from the Typhoon to the Zero to work on the landing gear.
    I will try to add brake lines like shown by Spiros @fiveten as well.
    What I noticed is how small those tyres of the Zero are compared to the Typhoon.
    Also the propellor is absolutely not comparable.
