If you have been following this build, by now you have realized there was a major problem with how the kit supplied decals worked out. These have to be the absolute worst set of decals I have ever used in all of the models I have built, during my entire life !
Luckily, a good friend, Chuck Villanueva @uscusn
has sent me some replacements. They arrived in the mail yesterday.
Chuck was kind enough to send me the partial decal set from his 1/48 Tamiya F-117, so I can still build mine up as the Toxic Avenger, since this is one of the options provided by Tamiya right from the box.
He also sent me some very nice leftover decals from a Caracal set for the F-117. These will be put to good use for sure.
So now without a doubt, I will be able to finish up the Night Hawk...
So I started stripping off the old ones. At first I used tape, but since these were glued down effectively using Future floor acrylic, they left some nasty marks behind in the paint. The Future had taken the shape of the wrinkled decals, and dried in this manner. I had no choice but to carefully sand off this remaining clear acrylic residue. You can see the "flat" spots in this next picture where the model has been sanded down to where the surface is now smooth.
1. White paint exposed
2. Decals were removed from here
3. and here
The V tail fins needed a lot of sanding... and since they were mounted, I decided to carefully remove them. After a little work, I had both of them off the main airframe, where I could sand them more evenly while they laid flat on a regular surface. I had to do this in order to keep from breaking something. It seems counter intuitive to break something in order not to break if worse accidentally... I also removed the nose wheel door, for the same reasons.
Here are the fins after they were sanded smooth and polished some.
The painted area around the canopy on the Starboard side broke through into the white base coat I had used for the inside color on the canopy. So tonight I touched it up, using Gloss Black enamel.
I will allow this fresh paint to dry overnight, and then I'll start applying the new decals tomorrow. Then it should go together quickly, and should be done soon afterwards.
I want to send a big shout out, saying "Thank You", to our good friend Chuck Villanueva. He is one of the many good people we are fortunate enough to have registered here on Imodeler. We seem to help each other out when we can. In the past I have sent parts and various decal sets out to others, and now it's being repaid in kind. This is not the first time someone has helped me out along the way... You know who you are and again I thank you.
And I will continue to help others when I can too. Pay it forward if you will.
Without his kindness, this plane would most likely still be sitting still. He provided the push I needed to get it done.
As always, comments are encouraged.
