Thanks John (@johnb), Spiros (@fiveten), and George (@gblair).
I plugging away at the PE for the Hangar structure. Like the earlier work , this involves balancing assembling, installation, masking, and painting in specific orders in order to minimize potential damage and make masking easier.
This structure has a lot of PE parts, some of which I have added and others which are still to be added. This later group includes a complex radar antenna and several handrails.
1. There is another platform that gets installed on top of this building as well as some small detail parts.
2. Ammo boxes and guns will still be added to both decks
If I were still a young boy, doing all this would be easier. I would just put it together and then paint all of it with a spray can. But no such luck nowadays! 🙂
The poor instructions with the PE set bit me again in that there were some areas where I needed to remove plastic but there was no indication of this. Fortunately, I noticed it before it became too difficult.
There is a mast that gets attached to this building as well. I am trying to decide if I want to install it now or later. Installing now would mean I could paint it when I paint the rest of the structure. But it also means I will have this tall, spindly, fragile thing sticking up for the remainder of the build. I'll probably wait until later. I may also make the mast from brass rod, however, I need to check and see how much of a taper there is on the mast. It may not be practical to duplicate the taper.
Another thing I am starting to think about is the weathering. I am not exactly sure how I am going to do this. The photos show a pretty weathered ship after the Guadalcanal battles (which is the time period I am modeling) and I am considering using those PE fractal templates in addition to freehand highlights and washes.
