It took me several days dividing my time between modeling four different projects, working on my real boat, doing chores, and dealing with other things, but I got the main gun turrets built up and two of them installed. The third will be installed later once I build up the main super structure.
I had a bit of a problem with one of them when painting. For some reason, the clear coat cracked and it looks bad, so I am going to have to try to clean them up with destroying the PE parts.
Building the gun turrets required first building 15 life rafts (5 per turret) from PE and resin detail bits from the Flyhawk set. Although they look a lot better than the kit parts, I wish they were 3D printed as they would have looked better. These parts required having a PE mesh CA glued to the bottom of the resin raft ring and then glue a set of PE ropes on the topside. The mesh is the same size as the inside of the rings which meant that they very easily fell through when trying to place them into place to glue. It took me about an hour to build these up.
1. Life Rafts from the detail set consist of three pieces. I needed 15 of them for the three main guns. They are pretty tedious to put together.
The turrets were initially assembled using the kit plastic barrels so I could make sure the barrel bags were mounted straight. Then I removed the barrels and glued on the brass barrels from the detail set. These look a whole lot better.
1. Added a small bit of plastic to simulate what I think is a sighting lens.
2. Left the plastic gun barrels on for initial installation so I could get them all straight.
1. Replace barrels with brass ones from the detail set. These look a whole lot better.
Life rafts were added, then the assemblies painted and two of them installed.
1. Even though I can only put on two turrets right now, I built up all three. Added the life rafts here.
1. One other small detail added besides the turret. The larger boats now have tillers. The smaller boats already had them.
Next up is the smoke stack deck which includes two smoke stacks and 6 single mount cannon assemblies. These assemblies have to be assembled from multiple PE, resin, and turned brass parts. Fun stuff!
