Here is a picture of the current status, shortly before the main paint layer. The red-oxide color is primer from the rattle-can, the white is a pre-shade I like to apply on the surfaces most exposed sun which - in Africa - scorched the good Earth from about the Zenith...
Next, I mixed an enamel color (Revell) from matt 5 (flat white), matt 35 (flat flesh) and matt sand 16 (flat sand). This mimics the Gunze color marked on the instructions marked "Dark Yellow" but in fact the color of the 501st heavies' Tigers was more inclined to sand than dark Yellow. I added a close-up for you to see what I mean. The advantage of mixing flesh instead of plain white to lighten de sand color is that the end result is somewhat warmer.
I also painted the remainder of the wheels & tools as you can see...
This has been a longer build thus far, combined with the Opel Blitz. I finished part of the dio but the main task of assembling figures, adding kit and painting will take more time. I hope David won't "Tiger" me when I'm a bit late for the ultimate GB reveal 😉
I'll keep you posted!
