Valentine tank 1/35 Tamiya
Started by neil foster · 38 · 6 years ago
    neil foster said 7 years, 1 month ago:
    This is now going to be my contribution to the Kasserine pass groupbuild, I will post a picture of the un- built kit when it arrives from ebay land.
    N.
    David A. Thomas said 7 years, 1 month ago:
    It's going to be a beaut!
    neil foster said 7 years ago:
    I did say recently that from now on unless there was no alternative I was only going to buy new generation Airfix or Tamiya and now I know why, my Tamiya Valentine tank has turned up from e-bay land and I literally cannot wait to get at it, the boxing and artwork are amazing, the moulding of the five tan coloured sprues is crisp and finely detailed and the instruction sheet is of the usual high Tamiya standard.
    I wasn't sure if this kit was the correct Mk for this conflict but it turns out the differences between the earlier Mk no's was all in the engines ,externally they all appeared the same, some did have the 6lb gun but they served at the same time so all's well.
    I will post pictures as I progress,Cheers N.
    Louis Gardner said 7 years ago:
    Very cool Neil ! I'll be watching this for updates for sure.
    David A. Thomas said 7 years ago:
    Wow, Neil, she looks to be a real beauty, and a perfect addition to the GB. Thanks for joining in!
    Bernard E. Hackett, Jr. said 7 years ago:
    I saw one as a build in progress at our IPMS meeting recently. Beautiful, clean molding, and the figure of the commander was as good as anything resin I've ever seen. Impressive!
    I may attempt the crew as well, figures are not really my forte but Tamiya have done everything they can to make it easy for me as they are superbly moulded.
    N
    Just a couple of pics to show where I'm up too, for me this amount of progress in under a week is amazing ,I'm usually still looking at the sprues and thinking of other things to do...
    Cheers N.
    Tom Bebout said 7 years ago:
    Nice addition Neil, look forward to seeing her done.
    Looks good Neil . Coming right along.
    Paul Barber said 7 years ago:
    I know what you mean about 'looking at sprues'! Well done on a great start!
    Wow this puppy is moving along a fine pace for me!, normally it would take me twice as long at least to be this far into a build . As you can see I have it primed up so that I can spray the wheels and surrounding area then I can finish them completely and add the tracks and paint them up before masking the whole area off,and attaching the wheel covers to paint everything above, I'm not sure if his is how regular tank builders would approach this but it seems logical to me, anyhow that's where I'm up to so far.
    The only problem with these Tamiya kits is they are so easy and enjoyable to work on that you find yourself ploughing through them so quickly.
    Cheers N.
    Nice progress Neil, and since they pop together so well, maybe another subject can be done before the deadline? The more the merrier.
    Tom,I've already mentioned I will quite likely do something else to David,if I do it will probably be an M3 Grant tank unless someone else bags it first, thanks for looking.
    N.
    Looking good, Neil! Sorry for the delay in response; my PC was on the fritz and a friend set me up with a Mac. It's taken a while to get configured.
