About the props Paul. I have seen pictures of some that were glossy. I'd imagine that's the most efficient in terms of aerodynamics, but doesn't do a thing for keeping glare out of your eyes. Most I've seen are a satin finish. I have a trick I use to get what I think looks pretty good. (We're talkin' high tech stuff here now!) I'll paint them flat black and after they're dry I'll rub them between my oily fingers. I puts a nice sheen on them that looks about right!
Can't wait to see your finished bird! I also like the one you have in the photo for the topic. If it's the same one I've seen elsewhere on the interwebs it's VERY shiny with great tonal variations!
By the way, you should totally search the web for a copy of the Detail and Scale book. I've had mine since I was little and need to find volume two! There are a lot of interesting tidbits on experimental stuff they did with armament that would make an unusual model. Ever see a B-29 with boobs? Well then, just check out the old Emerson barbettes! (This plane also had two Martin turrets on top and two Sperrys in the belly instead of remote turrets.)
