Casting lead nose weights.
Started by Allan J Withers · 4 · 4 years ago · lead weights, nose weights
    Allan J Withers said 4 years, 2 months ago:
    A basic guide to making lead weights to avoid tail dragers ! ------- step 1 = pour some casting plaster in where you want the lead to go, pic's 1 to 5, -------- step 2 = allow to dry and remove any areas that will trap this in the mold, ----- step 3 = mount this on a base and box it in, pic's 6 to 8, ---------step 4 = apply some mold release all over, Vaseline works, pic 6, -------- step 5 = pour in some casting plaster and hope it comes apart when dry, pic 8, ------------ step 6 = allow this to dry thoroughly before pouring in molten lead or the water retained in the plaster will boil out and spray molten lead all over every thing including you ! allow time for it to solidify before carefully removing the hot lead from the mold !
    This is so cool, Allan @kalamazoo! Thanks for all this info and technique!
    Great stuff Allan (@kalamazoo). What do you use to melt the lead? I suppose it might take a bit of heat?
    Thanks Spiros, ---------
    Thanks Erik, I used to use my gas stove but now I use an LPG torch, can use electric cook top !
    ALSO REMEMBER LEAD IS TOXIC !
