Clear coat/white spirit issues. Help needed
Started by Ben Walmsley · 6 · 10 months ago
    Ben Walmsley said 10 months, 4 weeks ago:
    G’day folks. I’m hoping someone can shed some light on this for me. I’m having trouble with my flat coat after using white spirit or enamel thinner to remove excess enamel wash. My process is to gloss coat, add an enamel wash, remove excess wash with either Tamiya X20 or white spirit, then flat coat. The problem is that once the flat clear goes on, previously invisible marks left by wiping away the wash suddenly appear. They are quite visible under the flat coat. This has happened to me a couple of times now, once with X20 (I assumed the X20 was the problem) and now with white spirit. I’m using Gunze aqueous clear paints. Could the problem be incompatibility with the paint? If not, what am I doing wrong? Any advice would be gladly received. Thanks in advance.
    John vd Biggelaar said 10 months, 4 weeks ago:
    This looks really bad, Ben @popeofchillitown
    I'm using acrylic washes myself, so not sure about this effect.
    Could it be that the wash and/or white spirit was not fully dry yet?
    Spiros Pendedekas said 10 months, 4 weeks ago:
    Hi my friend @popeofchillitown! I think it is due to the flat coat that you have these issues. Not due the quality of the flat coat (Gunze are superb), but due to the nature of the flat coat, which absorbs the diluted with white spirit enamel wash. Maybe applying an acrylic gloss instead of flat coat would be better, then do the wash and seal everything with your flat coat.
    Andrew H said 10 months, 4 weeks ago:
    What gloss coat and matte coat are you using?
    Pedro L. Rocha said 10 months, 4 weeks ago:
    Ok, although I don’t use those specific gloss/flat brand I’ve been using the same steps you describe above after the paint job on the kit is done.
    Now I use mainly oils washes but occasionally I also go for an enamel- using MIG starship wash. However for its dilution and removal (using a makeup cotton pad) use Odourless thinner.
    For gloss I always use acrylic products, but for the flat I go for lacquers. That said (so far) I never had an outcome as yours
    I’m thinking it must have something to do with the gloss coat as Spiros said. The wash/thinners sat for a week before I applied the matte coat so it was definitely dry. It’s strange because I dilute oils with the same odourless white spirit and use them over the matte coat with no issue.
