G’day folks. I’m hoping someone can shed some light on this for me. I’m having trouble with my flat coat after using white spirit or enamel thinner to remove excess enamel wash. My process is to gloss coat, add an enamel wash, remove excess wash with either Tamiya X20 or white spirit, then flat coat. The problem is that once the flat clear goes on, previously invisible marks left by wiping away the wash suddenly appear. They are quite visible under the flat coat. This has happened to me a couple of times now, once with X20 (I assumed the X20 was the problem) and now with white spirit. I’m using Gunze aqueous clear paints. Could the problem be incompatibility with the paint? If not, what am I doing wrong? Any advice would be gladly received. Thanks in advance.
