Tamiya 1/48 D.520 WIP - With a question
Started by Editor · 91 · 9 years ago
    George Williams said 10 years, 1 month ago:
    Your attention to detail, and your workmanship, put me to shame, Martin!
    Editor said 10 years, 1 month ago:
    George, allow me to disagree.
    Attention to detail is merely related to how much time one is prepared to spend on a model (at the inevitable expense of testing the builder's patience). As mentioned previously, I'm in the AMS mode this time, but this is somewhat out of the ordinary for me. I'd usually prefer OOB, staying away from any shape corrections, rescribing and aftermarket, especially photoetch!
    As for the workmanship, I admire modelers who can do things just right, quickly. There are many here at iModeler who can turn out a gorgeous-looking model every month. I'm afraid I can't do the "quickly" part, meaning that I'm probably overdoing stuff. But I guess it's all OK as long as everyone's having fun with what they do.
    Just my 2c. And I do admire your bikes 😀
    Bernd Müller said 10 years, 1 month ago:
    AMS or not, its a great build, and the D.520 is one of the most beautiful airplanes, with a prop on.
    Nice rivets 🙂
    Weeks pass by without me getting enough time at the modeling table. I recently realized that I won't be able to finish this by Oct 31st. I guess I will just keep going on until it's finished 🙂 Wouldn't like to miss the remaining fun!
    State of the work recently, windscreen on, everything ready for painting.
    Corrected gun ports... this was achieved easily by "floating" some Mr Surfacer around the openings.
    Clear wingtip lights - my addition.
    Preparing for the camo pattern...
    Rick Wilkes said 10 years, 1 month ago:
    Martin keep at it, you've got to much really fine work invested to put it on the "Shelf of Doom" just because the deadline passes. 😉
    Seamus Boughe said 10 years, 1 month ago:
    You and I are in the same situation Martin. A lot of work invested but not enough time to finish it all. I doubt my Hurricane will be finished by the deadline, but I am going to keep going until she is done.
    Hi Martin, finish this one, its great and deserves to get on your display and on the headlines as well. Your work on this little (and beautiful) kit is impressive.
    Simon Whitney said 10 years, 1 month ago:
    Keep going Martin, I have still got to finish off that P 47 D yet from the previous GB.
    The shelf of doom is just another name for put on hold...
    Editor said 10 years ago:
    Like a wise man said... what General Weygand called the Battle of France is over... The production of my Dewoitine continues, albeit slowly, under the terms of the Armistice (read: overtime).
    Painting time gives a space for another interesting bit of research. As most modelers of French aircraft would know, the tricolor camouflage was sprayed freehand at the factory with no predefined patterns, even with the goal of ensuring that no two aircraft were alike.
    I've seen many scale models where this knowledge was translated to a freehand airbrush job with large sweping patches of each color. Also the suggested kit paint scheme goes along these lines.
    However, many period photos shows that these large fields of color aren't necessarily reflective of the real process.
    To be on the safe side, I took the scanned photo showing the upper wings of the real a/c and stretched it in the graphics program to match the wing drawings. To my surprise, the result was a rather "snaky" pattern which I thought looked more attractive. It also formed a basis for the paper masks.
    Similar procedure was then applied to obtain masks for the fuselage sides and horizontal tail.
    --- pic6 not found ---
    The upper surfaces were first painted Gris Bleu Clair overall (Xtracolor RAF Ocean Grey), then masked for Khaki... (Xtracolor Faded Olive Drab)
    And lastly, Chocolat (Xtracolor Ombre Calcienne)
    Soon time for decals!
    Bernd Müller said 10 years ago:
    Masking with a wow factor !The "right" stuff after my third attempt to get the camo on my Jagdtiger correct.
    You are using "flying" masks to archieve not so hard edged colour borderlines ?
    Looking very good.
    Rick Wilkes said 10 years ago:
    Glad to see you're still at it Martin. What are you using to keep the edges of your masks "aloft", rolls of tape or Blu-Tac? Thanks again for all your coverage of Telford, some of your pictures at the museums were very Deja Vu, I'd been in exactly the same spot last year.
    Simon Whitney said 10 years ago:
    Looking great Martin, I am enjoying this build.
    No blu-tack underneath; I felt that this was enough complicated without it!
    I will be getting hard demarcaion lines but hope to be able to soften them up a bit (if needed) by polishing later.
    I don't think I've ever heard of polishing to soften the edge of a color transition before, but it certainly makes sense. What do you use, a 6000(+) polishing cloth, or something similar?
    I've learned this trick from a friend who used to polish all his a/c paint jobs to great effect.
    Previously I had been using Gunze/Tamiya Polishing Compound put on a soft cloth and some gentle polishing in circles. I reckon that a polishing cloth would work, too, without the trouble of the residue Will try it out with my new polishing cloths brought from Telford.
