'1936 Ford Hot Rod
Started by AL HOFFMAN · 24 · 9 years ago · "36 Forde
    AL HOFFMAN said 10 years ago:
    This is for the "same kit contest" for a club that I belong to. To be finished in early December. It is the recent rerelease by AMT of a kit from the 60's. I have an original in my collection that has a list price of $1.49 this release $26.99. Go figure.
    Anyway this one will be a little radical. I have started gluing the lower body shell back together after sectioning (cutting as horizontal section out) on a 1:1 three inch front rake (taper). I want to use as much of the original kit as possible but the rules say you just have to start with this kit. Anything goes. I have a vision of the end product in my mind. I'll see how close I get.
    Bernd Müller said 10 years ago:
    Good luck with this project Al 🙂
    Rob Pollock said 10 years ago:
    A chopped low-rider?
    George Williams said 10 years ago:
    You're a brave man chopping it like this, Al, but I'm sure it will turn out fine, looking forward to seeing your progress!
    It will be low Rob & full fendered.
    Gregor d said 10 years ago:
    Ooh this looks a bit good Al. I look forward to your progress updates.
    Jack Mugan said 10 years ago:
    This sounds like a real fun project……looking forward to following your progress.
    Thanks to looking at the background of the Honda F-1 car your building I got interested so I went & bought one. I blame you George.
    Don't blame George, we're all slaves to our private passions...
    That's ok, Al, you can blame me, I'm sure you will enjoy it. I blame my friends on iModeler for everything!
    Putting my worn out saw away now & starting to assemble the body. Wanted to show the grafted plastic before sanding. This is required because of the body sectioning. I like to use as much plastic as possible before the filler. The rumble seat lid was a sloppy fit so I created an inner lip on the body & ran a shim around the perimeter of the lid itself. This will be glued in place but I think I'll keep the seam.
    I have been trying to make my mind up whether to do a chopped top version or a roadster with a Duval windshield.
    The running boards are now gone. The center section of the frame is cut out to get rid of the molded in exhaust. The X-member will be reattached. That is the Duval windshield laying there.
    Added a couple of shots of a club meeting at my house this week. It was a contest night. The subject was Resin. Complete kits, conversions or just parts.
    Simon Whitney said 10 years ago:
    Looks like you have had a great time there Al, some fine motors on show.
    The Ford is coming along nicely.
    I like the look of that Duval windscreen, and your club night looked pretty busy with some smart looking vehicles there.
    AL HOFFMAN said 9 years, 11 months ago:
    Thought I'd post an update before starting to shoot primer & cover all the work up:
    Shows where the frame was cut away from the floor pan & the floor pan reattached to the fender assembly:
    The three major assemblies getting ready for primer:
    Couple of shots of the way it will look when done. Can't do the doghouse assembly until the body is attached to the fenders. The body has been sectioned on a 3" forward taper & needs to be in position to know how much to cut down the engine side panels:
    George Williams said 9 years, 11 months ago:
    Looking sweet, Al, it will look even sweeter with the paint.
