This is my progress so far on the Valentine tank ,as you can see I have the wheels and suspention finished and weathered and the rest of the tank built ready to mask off the finished area and paint/weather the rest, I am going to add some chipping ,rust and oil staining here and there but not go crazy, there are also the various bits and pieces to add to the deck ,these include a wooden box and some hand tools.
If you look carefully you will see I had to add a thin fillet between the deck and the side skirts ,this is because I went wrong somewhere along the way when building up the drive wheels (pic 5), I think I may have not closed up this assembly tight enough as both of them stick out 1 or 2 mm too far with the result that the skirts will not butt up to the deck sides, by the time I got this far along it was way too late to do anything about it so an alternative had to be found, once it is all painted no-one will see .
The next time you see this will be at the grand unveiling but I have a couple of ideas on the back burner for other additions to this group build.
Cheers for now N.
