Vallejo Paint
Started by AL HOFFMAN · 8 · 10 years ago
    AL HOFFMAN said 10 years, 6 months ago:
    Need some input from a Vallejo user. I'm trying it for the first time on my D-Day Typhoon 1b & I'm having trouble poor adhesion & it being easily damaged.
    I put down a primer coat of Alclad II grey like I always do when using acrylics. First noticed the if I touched the paint with the back of my fingernail it took the color off down to the primer & now as I mask the upper color the it is lifting in small areas. I ran the tape across the palm of my hand four or five times before it touched the model.
    Does this paint need to be sealed after every coat?
    Seamus Boughe said 10 years, 6 months ago:
    I cannot offer you any advice Al, but I thought I would let you know that I also never had any luck with Vallejo acrylics or any other of these newer acrylics that come in those fancy tubes. Poor adhesion and covering. I have seen others get wonderful finishes using this paint line, though. I too, would like to know what the secret is to getting a good finish from this paint.
    bob mack said 10 years, 6 months ago:
    i think your supposed to use the black cap for airbrushing and the white cap for handbrushing
    I'm using "Model Air" white cap which is supposed to be pre-thinned for airbrushing.
    Dmitry Stropalov said 10 years, 6 months ago:
    I'm using Vallejo paint a lot (about 2 years). I use Tamiya or Mr.Surfacer 500 primers, because Vallejo's primers are more useful as a base colors. Even for Model Air I always use an Airbrush Thinner and Retarder Medium. Then I always apply paint in a very thin layers (3-5) and allow paint to dry up to 2-3 minutes between applying layers. And I try not to touch painted areas as well.
    I think you answered my question about it being easily damaged when you said you try not to touch it.
    I have both the Vallejo thinner & retarder but stopped using them because they were like gel in the bottle. Is this the way it is supposed to be or do I have stale product?
    I'm looking forward to your Typhoon on the D-Day build because the Airfix version is what I am having the paint trouble on.
    Retarder is a gel, right, and it is used in a very small amounts. And what about thinner - I think that you have a "Thinner Medium", because airbrush thinner is more like water or spirit. Anyway, compared to Gunze or Tamiya paints, Vallejo has the lowest aghesion.
    Simon Whitney said 10 years, 6 months ago:
    I am not sure Al, but I was told to build the coats of Vallejo lightly and to give it a reasonable cure time.
    I use Alcad Grey Primer and have no real problems with it.
