As you know I've been working on replacing panel lines, etc getting ready to test out my new UMM decal rivets. I decided to test them on the Stuka, figuring that if I get it right I'm points ahead. So following the directions to the letter, I sprayed on Mr. Surfacer 1000 as a base. So far so good, except;
My replacement panel lines where horrid. The width seemed okay but they were mountainous. I hate it when I outsmart myself.
Anyway, bordered the offending panel lines with tape and sanded down to it, cleaned up and touched up the Mr. Surfacer.
Now back to the UMM rivets. For "free form" use like I'm doing, maybe a bit to finicky. More time consuming than the Archer rivets, because you really do need to leave them alone for 2-3 hours before taking the backing off. So here's what they look like.
They are very fine, and if I was using them on a model without any rivet detail, I think the effect could be stunning. However, again, I'm trying to get a fair match to kit rivets and the UMM rivets are so much "in scale" that they just won't do. You can see in the lower right corner the Archer rivets I've already started laying down.
This is a broader view of the replacement rivets and the reduced panel lines.
Once again "accuracy" dies on the spear of expediency. 🙂
