RAF Control Tower Diorama
Started by Gregor d · 56 · 10 years ago
    Gregor d said 10 years, 5 months ago:
    Here is my first (?) contribution to the BoB Group Build. The venerable Airfix 1/72/6 control tower. As you can see from the pics there is not much to the basic kit, which even lacks glazing for the numerous window frames provided. It is my intention to mount the finished build on a base, with supporting figures, and vehicles. I have also the Airfix 1/76 scale Bofors gun and tractor, which looks a nice little kit, and should compliment the control tower. Anyway heres all the bits ALL i have to do now is assemble them in a competent fashion. This is my second attempt at a dio and hopefully not my last...! Works will start shortly by priming all the plastic, progress pictures will follow in due course.
    AL HOFFMAN said 10 years, 5 months ago:
    A different & welcome contribution Gregor.
    I read the discussion in the other posts about attaching the clear parts. I'm not familiar with the Revell clear glue product but an alternative is simple white glue, Gator Grip if it is available to you or Elmer's white glue. Takes longer to dry but the advantage is you can remove the excess with water. The Gator product gives an extremely strong bond. Future or clear gloss paint is another possibility.
    I look forward to your progress because your updates are always informative.
    Cheers Al, i've got white glue, and Humbrol Clearfix, so i'll given them a go - if not them clear plastic off food packaging it is!
    Simon Whitney said 10 years, 5 months ago:
    Go for it Gregor dear chap.
    With the Bofors as well , it will make for an interesting dio.
    Don`t forget the buckets etc round the building.
    Simon.
    George Williams said 10 years, 5 months ago:
    This will be a good diorama, Gregor,with lots of opportunity to add those vital detail touches. I seem to recall that the RAF had a certain number of 'standard' designs for their control towers, I don't know which one the Airfix kit is supposed to be, but, I think, there is a website called something like RAFcontroltowers.co.uk, it's probably worth searching for.
    Aaaaaargh, I checked out the website George, and it looks like Airfix have made a bit of a faux pas with their control tower! The kit appears to be too narrow! If you look at the picture i've attached you will see that the type of tower looks right but it has 3 rows of windows not 2 as depicted by the kit. I'm gonna have to get the builders in!
    Gregor, Issue 38 of Airfix magazine has a build review of this kit in a diorama setting. It was built with the dimensions & windows in the kit. Also shows some mods using a PE set.
    I don't know if you can get to this article online or not.
    Maybe there was more than one size tower. Don't let it stop you from building it.
    neil foster said 10 years, 5 months ago:
    I'll bet Airfix took there dimentions from a reliable source ,there was probably more than one type of building depending on the size of the airfield, just build it as is mate.
    N.
    Don't worry folks I'm still going ahead. Its just that the source on the net showed none with the narrow frontage. I was looking at the kit tonight and to extend it would mean a bit of a faff.
    Rick Wilkes said 10 years, 5 months ago:
    Drive on, Gregor you've got the right attitude. I've let myself get discouraged by trying to fix every little thing on a build. Takes all the fun out of it.
    Seamus Boughe said 10 years, 5 months ago:
    Don't sweat the small stuff, Gregor. I'm with Neil on this one and I am sure Airfix did their homework. There were many different types of control towers. I have an old 1/72 vacuform control tower made by a company called MODAKIT in my stash. The kit is very similar in style to the Airfix kit and even has the two window front. I am certain MODAKIT sourced their design from the real thing also. Like Neil said "Just build it as is mate".
    You are all right of course, and theres plenty to do on the basic kit without thinking about making it bigger! I'll bash on then...
    Gregor d said 10 years, 4 months ago:
    The story so far...I've started building the bofors gun and tractor, which as you can see from the pictures they are almost ready for painting. I have been pondering the control tower and have only make tentative progress here. As you can see from the assembled back and side walls Airfix provide no internals for the main building or even a suggestion of what might be inside. I have found an Air Ministry plan for the ground floor (see images) but this is for the more common type of tower, its still interesting to see what was in there. I've found photos of the Airfix type featuring the narrower frontage but from what i've read it would appear these were found on lesser airfields or those of a more temporary nature ie with grass landing strips rather than runways. Any way thats me out of the blocks so to speak next stage is deciding what to put inside the building. I have done a bit of glazing but this will be slow and a bit tedious given the amount of windows there are!
    Rob Pollock said 10 years, 4 months ago:
    I must say, your individual image above looks remarkably like the control tower at Rougham in Suffolk, but which was used as both a USAF bomber base and an RAF base in its time, and now houses a small museum of artefacts. And, I see your image above is of another Suffolk control tower - Martlesham Heath - not unusual as the same builder was used to construct a number of these units in the area (probably less than 30 miles apart).
    http://www.rougham.org/history.html
    May well be Rob, I did a bit of digging on the net, and can't recall which one is which but the restored example, I think, was also a museum. Again these conform to the wider 3 window towers that seem to be more common place in more widely developed aerodromes from the time.
