Italeri Macchi Mc. 200 Saetta 1/48
Started by Chuck A. Villanueva · 55 · 12 months ago
    Erik Gjørup said 1 year, 2 months ago:
    Good steady progress! Keep it rolling @uscusn
    John vd Biggelaar said 1 year, 2 months ago:
    The engine looks great already, Chuck @uscusn
    Is the trolley part of this kit as well?
    Chuck A. Villanueva said 1 year, 1 month ago:
    Hi Pedro I wasn't aware of any grumblings about the kit frankly don't care. It looks like a Saetta Mc.200 and that is good enough. What are the issues?
    Thanks Eric, it does build rather quickly just enough details that enhances the overall model.
    Hi John, thanks, the yellow trolley is from the Tamiya MiG-15, the stand is from the Modelsvit F-82G
    With the engine assembled, next is to assemble the engine cowling.
    Made up of 4 pieces, will mate just the 3 halves for now and leave the 3rd panel off for now as this can be displayed open.
    The engine slips into a pair of notches and settles into the cowling, fit it good not tight where you have to wrestle with in some cases.
    Next is to attach the bulges around the cowling and lower intake scoop.
    Starting with the intake scoop is attached below the cowling.
    Several individual bulges are then attached around the cowl, some are already moulded into the cowl.
    After the exhaust stacks are attached, then I preshade the cowl with Tamiya semi gloss black
    With Black in the airbrush, I go ahead and preshade the undersurfaces.
    Using Tamiya Yellow, I airbrush the cowling. And a mix of Vallejo Copper,Steel to paint the cowl ring. Then attache the ring to the cowl.
    next some final clean up, attach the windscreen and mask
    more to follow
    John vd Biggelaar said 1 year, 1 month ago:
    Some really nice work on the cowling, Chuck @uscusn
    Erik Gjørup said 1 year, 1 month ago:
    The color on that cowl ring is looking great.
    Thanks John & Erik, similar type of finish that you will see on some British aircraft such as the Beaufighter.
    Masking off the yellow ID band and lower wing tips. The pre shading is then completed over the airframe.
    Next is to mask off the canopy and the open style of side drop down windows.
    Once the masking is applied, in this case not long with the minimal amount of glass on the Saetta. The exposed framing is painted the interior color of Pale Green.
    Next is the under surface color of Italian Lt Blue Grey.
    Airbrushed the Lt Blue Grey, don't forget to the gear doors and lower flaps.
    Next up more masking, and prepare to airbrush the upper paint scheme.
    More to follow.
    Spiros Pendedekas said 1 year, 1 month ago:
    Great job on the engine and ditto painting results, my friend @uscusn!
    Very nice painting progress, Chuck @uscusn
    It is looking better all the time @uscusn. The masking of the glass may be fast, but that large hole needs some serious filling in I guess?
    Anthony Ricco said 1 year, 1 month ago:
    This is looking really really amazing Chuck @uscusn. Keep up the awesome work.
    Chuck A. Villanueva said 1 year ago:
    Thanks Spiros, the fun part is next.
    Hi John, what is nice is the paint going without issues.
    Hello Eric, no that is a clear window not a hole, unless your pointing out the natural opening that is unique to the Saetta.
    Hi Anthony, thanks and appreciate that.
    Next up is airbrushing the 3 tone upper surfaces.
    Before painting the upper surfaces, this would be a good time to install the elevators to the horizontal stabs.
    I decided to have these drooped down. Just to add some character..
    Now to airbrush the tu-tone Green and Red Brown colors to the upper surfaces. The two shades are very close and difficult to distiguish.
    The upper colors also wraps around the leading edges of the wings and horizontal stabs. These have been masked off for a hard edge.
    Now the Tan smoke rings are freehanded over the upper surfaces. Random clusters of 3 in a circular pattern, faded to a solid tan blended into each ring. Starting slowly and knowing that I have a Veltro with a similar scheme but this time the tan over the Green camo verse Green over tan. Still it takes about an hour to do lay the rings.
    Next is to remove the masks over the Yellow Id markings. Silver pencil is used for high wear areas, edges where paint flakes off, hatch and doors edges.
    The lower masks are removed.
    Next a clear coat is applied.
    Next up apply the markings.
    More to follow...
    Fantastic painting, my friend @uscusn!
