Today I didn't get as much bench time as I originally planned for.
But I did get some stuff done on both planes. Please follow along and I'll explain.
This is Corsair #740. The paint demarcation line is straight under the engine cowling. It also had a single radio antennae. It was mounted ahead of the cockpit. So I installed this part before painting the NS Dark Sea Blue.
I also installed the clear gun sight, armor glass inside the windscreen and the rest of the canopy assembly. I decided to close this one, after doing an online search, and watching a few VMF-214 videos on YouTube. Sometimes you see the canopies open while parked, other times they are closed. I decided to close these two Corsairs after seeing several rain soaked F4U's in the videos as the Blacksheep were entering them. They had to press the enclosure release, slide the canopy back and then enter the cockpit. It looked as if it had just had a good amount of rain fall on the island, so it was probably a good thing the canopy was slid shut at the time.
So mine will be closed too. Many of my Corsairs in the display case have open canopies. It's nice to mix it up once in a while.
1. This will get cut off
2. Canopy installed
This one will be #883. It had a single antennae too. However, the antennae was mounted behind the canopy. I added the second one in front of the cockpit, and will let it dry overnight. Tomorrow I will cut it off, and smooth up the area. There is a hole in the fuselage for this front antennae, so it had to be filled. This was the quickest, and hopefully easiest method to do it. Tomorrow I will know more.
I also installed the cockpit clear parts on this one too in preparation for painting the Dark Sea Blue.
Here you can see how the paint wraps around under the nose on #883. You can also see that for now, it has two antennae's and the clear parts are in place.
This shows how these two F4U's look right now.
The next steps will be to mask off the walkways on the wings, and cut off the forward antennae on #883. Then maybe tomorrow I will get to spray the Dark Blue.
As always, comments are encouraged. Thanks for stopping by.
