John vd Biggelaar (@johnb)
Thanks my friend ! I'm happy to report the way I used the kit supplied antennae to fill the hole worked out perfectly. I didn't have to use any filler at all. I have a good picture showing the results coming up soon.
Spiros Pendedekas (@fiveten)
Thanks buddy ! Please tell QC1 and QC2 that we said hello from both Sandy and I. She was asking about you guys earlier today.
George R Blair Jr (@gblair)
Thanks George ! I can only imagine how hot it got inside those planes, especially in the South Pacific. You have experienced this firsthand, so you know. Add in the rain and getting things wet that shouldn't be, is another reason to keep the canopy closed.
I have been inside some of the Warbirds like a natural metal B-17, and even the camouflaged B-17 and B-24 are downright unbearable in the hot Florida summer time. I have crawled through them from one end to the other, with none of the windows open... believe me it gets pretty close to unbearable inside. There's no insulation in them, other than what is on the sidewalls of the cockpit of the 24's and 17's. The fighters didn't have any insulation at all.
I know that our M-60's and M-1A1's were also VERY hot inside during the summer months when we were operating them in the desert. I've seen the temperatures close to 120 degrees Fahrenheit inside the tanks, and our tools would be SO hot, you had to wear gloves to keep from getting burned when you were performing maintenance. Not fun. We didn't have air conditioning in our tanks either...
By the way, your Panther jet looks AMAZING ! Thanks for participating in our group to honor Jim. I'll comment on your headline article soon.
Brian Mennenoh (@brithebuilder)
Thanks for the kind words. They are sincerely appreciated.
Eric Berg (@eb801)
Thanks ! It has taken me some time to get used to it. I started out many years ago with a Testors Aztek 470. It ended up breaking because it was plastic, and they would no longer honor their so called "lifetime" warranty.
So I got an Iwata HP-C plus, but it wouldn't do the fine lines I wanted. It's a good airbrush otherwise. I use it a lot to paint aircraft that are a single color, like an overall Gloss Sea Blue Corsair or Hellcat.
I ended up getting this one you see here. It's a German made Harder and Steenbeck. I think it is called the "Evolution". I can check to make sure if needed. It has the ability to paint everything you would want to, by swapping out the needle and seat, which comes available in various sizes, from .010 to .040 sizes. I use the .010 or .015 for the fine lines you see here between the colors. It takes about a minute to swap out the sets. It is the best airbrush I have ever used.
The MAC valve is used to adjust the air pressure down even lower. It's also designed to keep a more constant flow of air, sort of like a back up to the regulator I use. You can spay some very fine lines using the H&S when the pressure is low. Having the paint thinned is also necessary. Otherwise it will clog up too fast. Enamels are more forgiving here. You would likely need to use a retarder in acrylics to slow down the drying time.
Today was a good day. Please stand by as I post up another installment. It's coming up next !
