Doctoral dissertation on B-17
Started by capt. R · 8 · 2 years ago
    capt. R said 3 years, 2 months ago:
    What do you think about this two photos? They show the same plane that performed the same number of missions (the lines on the fuselage can be counted). Is there a painted stripe in a color other than natural aluminum near the target post, or is it an illusion?
    David Butler said 3 years, 2 months ago:
    illusion
    @dbutlr I think so too, although this photo gives food for thought ...
    Andrew H said 3 years, 2 months ago:
    Most definitely painted, given the clear line of demarcation, and reflective differences. A little bit of research turned up that 95th BG B-17s has stripes added to their nose sections around July '44. Specifically, planes from the 334th, of which "Worrybird" was assigned had a yellow stripe. This makes sense, given that the color looks like a brighter hue... minding that many colors look widely different in black and white, depending on a number of unknown factors. Regardless, photos of other 95th BG B-17s online also show red, blue and green, which matches this reference:
    https://95thbg.com/cms/2019/12/6/camouflage-and-markings
    Scroll down to "July 1944" for the correct notes.
    John vd Biggelaar said 3 years, 2 months ago:
    @lis, it looks like to be painted. On the second picture the brightness is turned extremely high and therefore it is not noticeable to my opinion. Correct me if I'm wong.
    Tom Cleaver said 3 years, 1 month ago:
    A painted stripe in the "squadron color" was frequently used on B-17s for additional identification. That's what this is.
    capt. R said 2 years, 11 months ago:
    @tcinla Thank You! These stripes were always painted, was there any regulation from the USAAF command for that?
    One more photo of Worry Bird.
