Join iModeler today.
Hi all! does anyone has an hint on how to glue/repair clear parts? I've just received a kit with a broken windshield... (mail fault, no doubt) It's just the corner, but I'd like to do it the best way that's possible. Thks
Depending on what your kit is you may be able to buy a replacement aftermarket part from Squadron or someone similar or maybe get a replacement from the kit manufacturer. N.
I had the same thought(s) as Neil suggested - short of that, if you want to try a "quick fix" in the meantime, I'd first try a [very] small amount of white glue. It'll hold the parts together and will dry clear. Just an idea.
