First Republic...1/48 IMAM Ro37 Austrian Airforce
Started by Reinhard Spreitzhofer · 17 · 1 week ago
    Reinhard Spreitzhofer said 2 weeks, 5 days ago:
    Not a new project, this was started on March 25th 2018 but soon did rest on the shelf of doom. Now my dad dares to continue it.
    Back then , started a build thread on Britmodeller, will copy that until the actual progress.
    Using the original Classic Airframes kit with decals from the new Special Hobby re-boxing. (The CA kit has fewer resin parts)
    slow progress
    The SH kit now has better engineering and some more parts for the cockpit. But with this CA kit you have to do some scratchbuilding.
    PE seatbelts from the kit
    like a Classic Airframes Fiat Cr32
    Like a Classic Airframes FiatCR32 back then, also this CA kit moved to the shelf of doom. Maybe my dad will take a new attempt in the future with the improved Special Hobby kit...
    the Special Hobby kit has better engineering and more parts for the cockpit frame, with the CA kit, it would have been better to do the frame and then glue it into the fuselage, but for that some scratchbuilding is neccessary, which my dad doesn´t really like...
    my dad decided to use the Special Hobby kit and use the CA one for spareparts if needed
    he could remove the frames from the fuselage halves and will insert the SH cockpit frame, should fit together
    new parts from the SH kit, the seats are from the CA one
    as mentioned, the SH kit has more cockpit parts than the CA kit, all in form of resin parts
    way better cockpit assembly with the SH kit than with the CA one
    a bit tricky cockpit alignment, let´s see how it turns out
    so far the progress in 2018, then my dad put it aside
    and now restarted in 2025, let´s see how long it lasts this time 😀
    Spiros Pendedekas said 2 weeks, 5 days ago:
    Looking excellent, my friend @grimreaper! I think it will be finished this time 🙂
    John vd Biggelaar said 2 weeks, 5 days ago:
    Great your dad continued with it, Reinhard @grimreaper
    Looking forward to it.
    George R Blair Jr said 2 weeks, 5 days ago:
    Ditto from me, Reinhard @grimreaper. This kits looks like a beast to do, but I am glad your Dad is taking a crack at it.
    Reinhard Spreitzhofer said 1 week, 5 days ago:
    slowly gaining shape
    cowl to fuselage fit wasn´t that good
