Join iModeler today.
1/72 Airfix, a change of subject from when I started building this kit, it was to be RAF ! -------- also building for my IPMS little lazy group build !
Hi Allan (@kalamazoo). I think this is your breakout from the pair. Sounds like this will be another airshow bird. Looking forward to the paint and decals.
Thanks George, yes aerobatic team !
Looks great so far, my friend @kalamazoo! Looking forward to your progress through this now separate thread!
Nice to be able to follow this Meteor separately, Allan @kalamazoo
Thanks my friends, Spiros and John, still filling and sanding !
canopy masked, a coat of XF 1 on, then some XF 14 all over, mounted on a new jig, still needs more filling !
Great progress, Allan @kalamazoo A very effective jig to hold the Meteor.
Thank you John, it works well, -------- more sanding and a bit of filling.
Excellent progress, my friend @kalamazoo! Excellent jig as well!
The iconic shape of the Meteor looks great, Allan @kalamazoo. Did you see that the reboxing of the 1/48th Airfix Meteor also features a RAAF scheme?
Good luck on those nasty seams, Allan @kalamazoo
Thank you, Spiros, Felix, I did see that, I only model 1/72 ! and John.
Some MM 37875 on as a base for the red, still a little bit of filling to do ! seams are looking better, only the final paint will tell !
Looks way better, my friend @kalamazoo! Nice priming with the MM 37875!
