Drilling out decals applied over holes
Started by Spiros Pendedekas · 9 · 2 years ago · Tips and tricks
    When a decal is applied over a hole or opening, like, say, the red decals applied over the Spitfire leading edge gun openings...
    ...some cracking or shattering might be locally experienced when trying to pierce-open the underlying hole (or any kind of underlying opening, like an underwing shell ejector chute).
    What I do is dip a toothpick into decal softener...
    ...then carefully pierce through the opening... The softener moistened tip will gently soften the decal locally, so it can be pierced without cracking...
    George Williams said 2 years, 4 months ago:
    Good technique, Spiros @fiveten, I do something very similar but before the transfer has completely set so that it is slightly soft and less likely to tear.
    Thanks my friend @chinesegeorge! Your technique sounds great, too!
    I used to tear off the transfers' edges around the holes upon "working" my micro drill or my blade tip in the hole/opening, the result looking frustrating.
    Great way to do this, Spiros @fiveten
    Thanks for sharing this very helpful and useful tip.
    Thanks my friend @johnb!
    Brian Mennenoh said 2 years, 4 months ago:
    @fiveten - That's quite a brilliant technique!
    Thanks my friend @brithebuilder!
    Cricket said 2 years, 3 months ago:
    @fiveten! COOL! Will keep that in mind 🙂
    Thanks my friend @bikequeen!
