Sixty years Germany divided
Started by Michel Verschuere · 117 · 2 years ago · Berlin Wall, DDR, East Germany, NVA, scratch
    Michel Verschuere said 3 years, 7 months ago:
    Thanks @fiveten @lgardner @airbum @tcinla
    I did not want to disappoint you! Here are some pictures taken in daylight, the PVA is now set.
    The goal is now to finish the exterior and base and then turn to the interior and the windows.
    I'll keep you posted!
    Michel.
    Looks even better now that it is dry!
    Thse surroundongs look 1:1, my friend @michel-verschuere!
    Even better in daylight!
    These days, I'm pushing to get the exterior done. Then I can finally turn to the interior and windows, which finishes the tower for 95% before final weathering and finalizing the landscape.
    Today and yesterday, I focused on the entrance to the tower, the railing there and the paintwork. Also, I painted the roof gutter and rain pipe. I bent 0.5 mm copper wire into a bracket for the rain pipe and painted that aluminum. The roof must remain detachable (otherwise there is no point in putting too much effort in the interior) so the rain pipe is fixed only by these brackets to the wall and via the lower end into the base of the diorama.
    Here are some detailed pics, the railing on the back side near the entrance is now fixed and final.
    Hope you like it!
    Michel.
    Love it, my friend @michel-verschuere!
    The entrance area looks REAL!
    The detachable roof does not look at all detachable, meaning that you have made a perfect application job there!
    Today I worked on the tower again.
    As you can see from the above picture, these guard towers were featured of a lightning protection. It runs all the way from the base to the top and connects to the railing on the roof. These towers were often the only high feature in the landscape and since the railing was metal, lighting bolts preferred earthing to the tower. Nothing as safe as a good lightning protection! Here is my crack at it:
    The way I did is was make a 1.5x1.5 mm base from 0.5 mm styrene with a hole in the middle. I bent a strip of 0.2 mm copper wire through the hole and fixed some black florist wire (the actual lightning protection wire). Black is not a bad color because anodized copper oxidizes in black. Copper is usually the material of choice for lightning protections because of its low resistance.
    I like the fact that the wire is not straightly running up the tower, it mimics the expansion that will have happened in bright sunlight over time. My tower is modeled still in use (lot abandoned) but it looks ok to my standards.
    Hope you like it too!
    Louis Gardner said 3 years, 7 months ago:
    Michel, @michel-verschuere
    These small things... they all add up to make an incredibly detailed and extremely accurate model. The addition of the grounding wires, all of the details on the roof (including the railing and lights) are simply magnificent. This will easily pass for the real thing once you are finished. The ground covering / grass and vegetation looks fantastic and even more realistic once the glue has dried.
    I will be watching for the next installment.
    Love he lightning protection wire, my friend @michel-verschuere!
    Like our friend @lgarner said, all those things add up to present an utterly realistic and extremely attractive model!
    Now today I turned to the windows. I cut pieces of transparent styrene over the entire length of a window and then cut small strips of white styrene as the window frame. This is tedious work, and there are 4 windows to be made, with frame parts on both sides. I think this will occupy me for the next hours.
    Finished the front window already on one side and dry fitted it just now. Here are some pictures. I intend to leave the window frames white, maybe weather them later a little bit. Note that thee is still protective back film on the window, it is lettered which is what you see on the pictures.
    Hope you like it, Michel.
    We love it, my friend @michel-verschuere!
    This is amazing work!
    Gute Nacht!
    Kalinichta Spiros! @fiveten!
    Finished all windows (exterior) and dry fitted them. Here are some pictures.
    Even if it is "just" squred windows there is a lot of work to build the frames with the correct edges - imitating frames that can open I suppose? Looking great.
    Today I worked on the interior and the back side of the windows. I made a ladder to fit to the ceiling, used only to access the roof. There is more work to be done on the interior but part of it will be tables OOB from a Dragon kit. Here are some pictures, the protective film is now removed and the interior of the 2nd floor visible.
    And here are some shots from the outside in the current state of affairs:
    I mainly used this reference picture since it is the only good view I have on the interior.
    Hope you like!
    Michel.
    Oh, my! This is wonderful, my friend @michel-verschuere!
