While having some black in the airbrush, I went ahead and did some preshading on the Vindicator. Might as well knock it out while doing the Devastator at the same time. No black on the fabric portion of the rear fuselage. Also paint the windscreen as well. Next is to install the rear sliding gunners glass right behind the raft. Then applying the Montex Masks as directed. While airbrushing the Blue Grey on the Devastator, I added some Light Grey (didn't have any white) to lighten for fading and sprayed the fabric portion to see if it would appear faded compared to the metal portions of the airframe which will be slightly darker, but lighter overall in appearance parked next to the Devastator when complete. The Midway based USMC Vindicators were behind in the maintenance cycle, very faded in appearances at the time of the Midway battle. So hoping to achieve to capture this appearance when finished. Next was to airbrush the black over the framing then apply the USN Blue Grey, slightly darker than the rear fuselage shade. Then remove the maskings from the glass. And encountered some residue left over on the glass, hmmmm. With that I will call it a day.
