OK, the operation--and indeed surgery--proceeds. Since any number of sub-assemblies are drying at present with a combination of hot glue, cyanoacrylate, and putty taking the time they necessarily must to do their work. I felt an update was in order.
I am replacing the stock surfaces with the Vector resin aftermarket kit. This has required some careful cutting and Dremel work on the vertical stabilizer/rudder, the ailerons, and the elevators.
Here's the work on the stabilizer/rudder, first in process, and next glued in place to indicate a yaw to port:
Here's the aileron work, with the port wing in process...
...and the starboard wing with a dry fit...
The horizontal stabilizer is here in process:
And here are my engine assemblies, previously shown, now in their cowlings and ready to glue into the wing assemblies:
That's it for the moment, lads. I appreciate the encouragement. I am working on a number of items at once but I am fast approaching critical mass and I believe I'll soon be at priming and painting stage.
