L.V.T.-1, a DB601 powered Hurricane, 1/48
Started by Erik Gjørup · 68 · 5 months ago · airbum, db601, Hawker, Hawker100, Hurricane, Yugoslavia
    Erik Gjørup said 1 year, 10 months ago:
    Thanks @davem – and welcome to the party.
    Wings
    about to be cut off that is!
    With the glue cured the tape came off, and the opportunity taken to show it with the far-from-finished nose dry-fitted
    I also need to cut out a bit of the styrene to make room for the exhausts as they extend a bit further back
    Now, where did I put that sandingstick?
    Nicely progressing, my friend @airbum!
    Another big surgery on the way, not much left from the original plastic, Erik @airbum
    Progressing nicely.
    Thanks gents - even less plastic left now!
    Oh no – the wings fell off!
    OK, that was intentionally.
    Having sanded most of a day, I needed to get some very visible progress, and out came the saw! As always, use the mirror-image to check the cut is straight.
    With one wing off, I dry-fitted to check how much work would be needed
    not a lot it turned out, so off went the other wing
    and on a roll, the wings were superglued in place
    followed by some filler – what a mess!
    And more sanding will follow. . . . .
    Eric Berg said 1 year, 10 months ago:
    It may be a mess now but once you clean it up it’s going to look perfect. Looking forward to the next step, Erik @airbum.
    Amazing craftsmanship, my friend @airbum!
    Must have been a nervous moment to get that sawing started, Erik @airbum
    The fitting of the new wings does look quite nice.
    Still some days left before I get to the bench again, so all the glue and filler will have a lot of time to cure before I go beserk with the sanding stick again 🙂
    Actually the wings were surprisingly well-fitting, even though they were just a bit too narrow (probably a consequence of the form and resin shrinking a bit) but that can be remedied by some more filing. . .
    More dryfitting on the LVT1 @davem, @gblair, @fiveten, @holzhamer, @johnb and @eb801 though not nearly as far as I expected as I had to take an extra shift at work this morning.
    Oh my, it’s a nosesitter. . . .
    With a massive engineblock and resinwings it is rather noseheavy.
    The nose is very heavy, and it does make me think about the integrity of the undercarriage.
    Of course it does not sit on the nose with some support at the undercarriage locations.
    I think the shape is nearly where I want it.
    Just needs a lot more styrenecard and LqS and sanding and stuff, but getting there.
    next up I hope to have it primed – perhaps just one more dryfit perhaps, but it is slowly moving the right way
    Pedro L. Rocha said 1 year, 10 months ago:
    This is some serious (and no doubt tiresome) conversion/scratch work Erik, I’m very impressed by your skill and will here. Besides some minor adjustments,I suppose some scribbing will follow no? Looking forward for the primer @airbum
    Ditto what Pedro said. That is some seriously impressive surgery you’ve done here Erik @airbum and it’s looking really good. You are fearless.
    Looking great, Erik (@airbum). You look like a surgeon with your precise cuts on the wing. I have never worried about the landing gear on a 1/48 plane, but that block of resin looks really heavy.
    A wonderful job so far, my friend @airbum!
    A lot of work done so far, but it will end up in an exclusive model, Erik @airbum
    The wing connection looks smooth already, just like the DB nose.
    Erik Gjørup said 1 year, 2 months ago:
    8 months has passed @holzhamer, @eb801, @gblair, @fiveten and @johnb, that is a lot of time (or a spring and summer of all work, no play), but today some visible progress had to be made. I suppose it should have been done some 6-7 months ago to let the glue cure?
    Legs!
    The LVT-1 got legs today – and exhausts.
    Starting with the exhausts, I used LF-model printed exhausts for the Eduard Emil – as the lower part of the nose is from that plane
    The plastic was also glued in place, to enable some more filling and sanding and filling and sanding and . . .
    The legs were glued using Revell Contacta, as it is my experience it will cure nice and hard over time
    and the nose dryfitted once again
    With the photos taken it is onto the back again to let the undercarriage set.
    It will once again get a lot of time to set properly.
    next up some more filling and – you get the picture…
