More posting problems
Started by Rob Anderson · 30 · 8 years ago
    Rob Anderson said 9 years ago:
    I can edit my own articles, but cannot comment on others comments, nor can I post a comment on other articles. I get the box to do the comment, I can type it in, but when the page reloads after saving the comment, my comment is not there.
    Site Administrator said 9 years ago:
    This seems to be a similar issue to that experienced by Greg @gkittinger
    Thanks for letting me know, as this means that we're at least having a pattern. Also, the problem seems to occur with comments, but not articles or forum posts/replies. At this point I strongly suspect that the trouble has to do with our recent core upgrade, where some elements of the comment form have been changed.
    The bad thing is that we're still unable to replicate this on our end and judging from the activity log at the site, other users are able to leave comments. This makes searching that bit more difficult, so please bear with us as this might require multiple tests
    I have now disabled the CDN caching to ensure that anything your browser reads is being pulled directly from the site. Any improvement?
    Stellan Schroeder Englund said 9 years ago:
    Just posted a Canberra cockpit article but can only add 6 photos, its says I´m over some limit... In my Firefly article I had a few more photos. My wrong or a general problem?
    Greg Kittinger said 9 years ago:
    I still cannot post a thing! Just tried again to comment on Stellan's wood grain article - no result!
    @stellan - would you please try to re-open (edit) the article & add the lacking pictures, what happens then? I'm afraid I'd need to know the error message in order to proceed.
    @gkittinger - most likely @robertandy has the same problem. Working on it right now.
    This is the text i get when trying to add more photos.
    Error: File is too big. The maximum allowed file size is 8.0 MB. Australien 2015 1341.JPG
    Do I have to resize them and save again or is there an actual problem...thinking if photos are bigger files as I used different camera for these photos...I can try add another article with photos from other camera.
    Tried to create new article; first with one photo. Worked fine, added another, not fine... Deleted the one photo i had and the file not working. Tried to add a new photo, not working. Getting same File is too big message.
    @stellan Re: Error: File is too big. The maximum allowed file size is 8.0 MB. Australien 2015 1341.JPG
    The system must have a restriction on maximum file size to prevent potential abuse of server resources. Actually, we have once increased this limit from 6 to 8MB to accommodate new camera models. Are these files really over 8MB each? The way to check (Windows): right-clik on the file name, then select "properties" from the menu, then look for what the "size" says.
    I'd be grateful for this check, and also for info on the camera model.
    Thank you
    Checked all photos, image info says ca 3,2-5,9 MB so they should be below limit. Using an EOS 700D for Canberra photos and an old point n shoot Samsung WB 550 for Firefly and other photos.
    @gkittinger and @robertandy. Thank you for bearing with me on this, now is the time to ask for another test.
    We have discovered that there was a high load on our database server, which BTW has been causing some trouble w/accessing the site this morning. Really, there's no way of knowing if your problems have been related to the database, but as we have now done a complete reset of it, I would like to ask you for another quick comment posting test.
    Your patience is greatly appreciated.
    Kind regards,
    /m
    Still did not work, sorry 🙁
    But oddly enough I could reply here?
    Yes, the problem seems to affect only the comments to articles, not group threads, activity stream or private messages. Yes its odd :/
    I tried as well - and no success. Still cannot comment.
    Bryan W. Bernart said 9 years ago:
    Worked like a charm for me. Added textual and photographic comments to the Midway build in the WIP section. Did this last night.
