FA 18F Super Hornet, A44-210, 100th annivarsary 1 Sqn RAAF, Amberly Qld 2016.
Started by Allan J Withers · 40 · 5 years ago · 1 Sqn, 1/72, Boeing, FA18F, hornet, nose art group build, RAAF, super hornet
    Jaime Carreon said 6 years, 1 month ago:
    You've been coming up with some wonderful schemes, Allen. Keep them coming!
    Allan J Withers said 6 years, 1 month ago:
    Thanks Jaime, a light coat of black on the canopy frames, top grey on and the masking removed, the stbd tail-plane needs some touching up !
    david leigh-smith said 6 years, 1 month ago:
    Starting to look the part. As Jaime says, you always have a great scheme up your sleeve...
    Thanks David.
    Some masking on and a coat of flat white on the undercarriage bays !
    Peter Hausamann said 6 years, 1 month ago:
    All clean and crisp so far.
    Like seeing how you mask the various areas. I've seen this yellow tape before. I assume it is specially for masking models. Does it stop paint from bleeding under it?
    Thanks Peter, large roll 49mm wide from my local auto paint shop, does a good job if pressed down properly, similar I guess to Tamiya but much cheaper ! ---------- a coat of gloss white on these now !
    Allan J Withers said 6 years ago:
    A bit of touching up with the top side color !
    Marc Barris said 6 years ago:
    Allan, you are really building some amazing models, keep up the great work.
    Thank you Marc, you also !
    Allan J Withers said 5 years, 11 months ago:
    Some more decals on !
    All the decals on and in the exhaust bits, also attached !
    Jeff Bailey said 5 years, 11 months ago:
    Beautiful!
    Thanks Jeff.
    Allan J Withers said 5 years, 10 months ago:
    Now with a coat of Vallejo matt varnish, working on the details !
