A 1/48 Scale Academy Bare metal and Primer Azerbaijan MiG-29UB
Started by George Johnson · 20 · 8 years ago
    George Johnson said 8 years, 8 months ago:
    I bought this 1/48 Academy MiG-29UB maybe 15 years ago and it's sat in my storage unit for that long. I decided to build it after I saw a photo of an Azerbaijan UB that was stripped of its paint. I decided to build it pretty much out of the box for the simple reason that there's not much aftermarket stuff available for. I did find a resin Wolfpack K-36D ejection seat set that I will use, though. For you rivet counters out there: I really don't care if they were or weren't used on this particular plane. There are a few minor fit issues with the kit and some raised panel detail, but nothing that can't be corrected. The cockpit has surprisingly good and sufficient detail. It should be a fun build with lots of cool effects possible.
    Craig Abrahamson said 8 years, 8 months ago:
    Looking forward to seeing how it turns out, George...I'm sure it'll be as good as your others.
    Thank you, Craig.
    Bernard E. Hackett, Jr. said 8 years, 8 months ago:
    George, neat idea, with photographic proof, no less. The nitpickers will have a spasm.
    Apparently it flies, unlike the photos you see of the former SovBlock stuff mouldering away in the weeds in farflung parts of the globe. Having grown up during the RED MENACE, it's kinda sad.
    Yes, it is kinda sad, but when you think that these are all weapons, it's not so bad. I wish they would preserve them better than they have because they're also a part of history.
    Here are a few more work in progress images of my 1/48 Academy MiG-29UB. I just finished painting the Wolfpack K-36D ejection seats, but will wait to install them later. I'll post photos of those at a later date as well. In the meantime, I've been working on the fuselage. I have to say that everything probably fits pretty well, but for some reason I couldn't get things to align properly. Not sure if it's the kit or me. Anyway, I used a bit of Tamiya polyester putty to fix my mistakes. I decided to give it a second, thin coat of putty after the first application as I found a few microscopic pin holes after carefully sanding the areas with 320 grit Tamiya sandpaper. All the panel lines will be re-scribed and rivets added later. 8000 grit will be used for the final sanding/polishing phase since this model will have partially natural metal finish.
    Richard Mcstay said 8 years, 8 months ago:
    I'll keep an eye on this one George, looks like an interesting project. I've got a 1/32 single seater in the stash, I'm a long way off starting it though!
    It is easy to forget when admiring the technology and engineering that goes into fighter jets, that they are infact weapons designed and built with one sole purpose.
    This hit home for me a while back when I was in the middle of building a SAM launcher. The exact same thing was used to shoot down flight MH-17 over Ukraine. I didn't post it for a while incase it was received in bad taste.
    George Johnson said 8 years, 7 months ago:
    Here's a sample of some tests I'm conducting on a POS Zhengfendu Su-27 for a MiG-29 UB I'm building. I used Alclad metallics, Mr Paint, Vallejo acrylics, and Ammo of Mig washes to simulate a Mig of the Azerbaijan AF stripped of its paint. I used Mr Paint Lemon yellow for the primer effects. However, it is a lacquer based paint so you can't used the hairspray technique for wearing and chipping the paint. My solution to that was to mix my own using Vallejo acrylics. I used German yellow, yellow, white and yellow green. The match is almost perfect and will work well for this model since the paint is so uneven and subjected to weather, use, and paint stripper. I used Alclad transparent yellow over Aluminum to simulate the treatment applied to some panels.
    Bernard E. Hackett, Jr. said 8 years, 7 months ago:
    George, Mr Paint? I thought it was Mr Paint Lemon, for a minute. Make a nice band name...
    There is a Mr Paint? I musta missed that one, and I thought I had a lot of paint. Like Mr Dissolved putty, etc?
    Yes, Mr Paint is a brand from Slovenia. Not to be confused with Mr Color, a Japanese brand. These are excellent paints. They're super thin and cover extremely well. http://mrpaint.sk
    The actual color name is Lemon Gray.
    Thanks, George! I had no idea. That color is perfect for what you're doing, too. Thanks for the link, fascinating. I always learn something here, keeping my aged brain exercised.
    My pleasure, Bernard. I just found out about them recently. I bought 5 or 6 colors intially and now I'm hooked. I ordered 8 more!
    Here's how the MiG-29UB is coming along. I'm nearly finished with the assembly and going am to attach all the little stuff that catches on everything else in the workshop and breaks off. It wasn't a bad kit to build. It has a few fit issues, but the overall quality is pretty good. I'm really not concerned too much with accuracy and things like that, and often build jets that look cool but may not be historically or physically accurate.
    I used Wolfpack resin seats and they not the best quality. Detail is a little soft and ambiguous in spots. They're not Aires or Eduard quality, but they're a fraction of the price.
    All the panel lines were re-scribed and some were actually repositioned in order to match the reference photo. It made sense to do that in this case because of the bare metal/primer finish this will receive.
    The exhaust cans are kit supplied because I wanted to keep after-market stuff to a minimum. I made new actuator arms out of very fine (and stiff) cardiac catheter wire.
    I haven't posted anything in a while, but here's an addition to my previous MiG-29UB posts. I re-scribed all the panel lines, polished the plastic about 900 times, and finally got down to adding the first coat of paint. I tried something different this time and I decided that I wouldn't put down a primer coat. I used AK Interactive Xtreme Metal Aluminum for the first coat. I wanted some of the imperfections of the polishing to show through as this will be a heavily distressed, airframe stripped of its paint. Some panels will be painted with various metallic shades including stainless steel, dark aluminum, steel, white aluminum and dull aluminum to make it a bit more interesting. The end result will hopefully look like the test I previously posted.
    George, looks good. I'm looking forward to the distressed paint job.
