Academy F8F-1 Bearcat, 1/48. 'The Fleet's First Superprop'.
Started by Harvey R. · 16 · 2 years ago
    Harvey R. said 2 years, 4 months ago:
    Introduction
    I'm very excited for Eduard's F4F, and one habit I've picked up recently is looking on eBay for any cheap deals. After missing out on a Beaufighter and Mosquito for criminally cheap, I did see this kit for a good price and figured I'd pick it up as a quick build. The Bearcat was an aircraft on the 'I'd like to do but not in the top 10 kits' list, and with the choice being an older Academy/Hobbycraft kit or a Hobbyboss one it was clear to me what I'd chose.
    I then put it in the oven to cook for a few hours, whilst we wait for it to bake here is one I prepared earlier:
    This older model is from the same boxing, I don't remember much of the build as I was 8~ but I do remember the box art. I'm not even sure how much of the model I did and how much was my Grandad happily building away at the birthday present I received, but I do remember saying the 'silver scheme is cool but I want the cat on it', to which he replied 'it's your model you can have both'.
    Regardless, here's a new Bearcat. Looking around online (mostly here) I've been made aware of several issues with the kit. Firstly is the cowl being the wrong shape, I'm hoping to rectify this with some sanding as the resin cowl seems to be a bit of a pain to find and probably will require an import from America which isn't worth it to me. There's also an issue of a pretty sparse cockpit, but it isn't worse than Eduard's Hellcat. Also either the landing gear/wheel bays are wrong on this or the Hobbyboss kit, but I'll cunningly avoid this by going for wheels up.
    As for which scheme I'm doing, I am currently undecided. It will be a US Navy sea blue scheme so the painting will be the same regardless. Ideally I want as early of a Bearcat as possible since VF-19 were operational and steaming their way to the Japanese home islands before the war ended but didn't arrive in time, that being said finding reference photographs of early Bearcat from 1945 is a bit rare. I'll keep looking and work out what numbering is needed (if any). If worse comes to worse the kit included 1946 scheme will do fine.
    The First Steps
    A small aircraft with clean lines, from a 1998 new tool? Yeah, not a complicated build at all. First step was to build up the simple cockpit tub, black and then interior green was applied ready for the brush work. The instrument panel was also painted black again ready for work.
    Same story with the fuselage.
    The wings were cut from the sprue and the wheel doors were test fitted, by clipping off some flat bit of the sprue (right where the sprue is marked with its corresponding letter) and gluing into the wheel bay I was able to provide a little bit of a seat for the doors to sit on. They actually fit really well and was so far the easiest wheels up modification yet, literally a 0 effort job (although I did cut a bit close on one of the door leaving a gap, my bad).
    Overall, not bad for maybe an hour in total work (excluding paint drying), the wing is fully assembled but you'll have to take my word for it until I whip the camera out tomorrow.
    A beautiful entry, Harvey @scalerambush
    Wheelcovers are nicely supported this way.
    Another good entry, my friend @scalerambush! This looks to be a solid kit, your skills promising to produce your usual masterpiece. Loved your pics of your already put together model.
    Great start, Harvey (@scalerambush). I built one of these a while back and still have another one in the stash. I have also recently been looking for deals on Ebay and have gotten some good kits at great prices. Looking forward to the rest of your build.
    John Healy said 2 years, 4 months ago:
    Nice work, Harvey.
    Harvey R. said 2 years, 3 months ago:
    Thank you all! It's shaping up quite nicely, I've got an F2G on the bench which is taking a lot of my time due to decal and painting issues but the F8F serves a nice quick distraction.
    Assembling the Fuselage
    First thing is the finish off the cockpit, honestly I didn't put too much effort in and just slapped on some aluminum chipping, largely as so little of it will be visible.
    The instrument panel has some interesting raised dials, but my brush just isn't cutting it. Maybe I need to finally buy a new un-frayed one!
    And here is the final look, once the pilot is in. Yeah, not a lot to see. According to my test fit the pilot should be able to just about fit in the pit after the fuselage is assembled, if not he'll need his arms to be trimmed!
    Once that's glued in I put the two fuselage halves together, a decent fit with no issues though as always it will get some work to hide the seam.
    The kit comes with the parts for the F8F-1 and -2, for this -1 it gets the smaller of the two rudders. It fits okay, but it doesn't line up with the curve of the tail so some sanding is needed.
    I figured why not add the wings too? Again, no issues with fit, and again it'll need the standard seam treatment on the underbelly but nothing out of the blue.
    All in all a quick build so far, decent fit, and very simple. I'll try and patch up those issues highlighted and get the seams treated, also maybe even get some paint on the engine.
    Nice, solid progress, my friend @scalerambush!
    A quick build indeed, Harvey @scalerambush, but a very decent one.
    Fitting seems very nice.
    Moving very quick and very nicely on this kit, Harvey (@scalerambush). When I built mine several years ago I used the "utility" paint scheme in engine gray and yellow wings with red stripes. I set aside the gear doors to add after everything was painted and then promptly lost them somewhere. So, now my model sits in the case without gear doors. Oops. Your plane with its door firmly attached is way ahead of mine. :o)
    Harvey R. said 2 years, 1 month ago:
    'Moving very quick and very nicely on this kit' - George, 2 Months Ago.
    Wellllllllllp.
    Back On The Bench
    Clearly, the Bearcat dropped off the priority list for a bit!
    From the last post the gaps were filled on the upper and lower side, and a tiny bit of rescribing was done over some lost details though not much since the kit isn't very detailed in the first place.
    Some work was also done to try and get the cowl a bit of a better shape, but... Ehhhhhhh... Its not perfect by any means, maybe slightly better, this one won't be entering a model competition anyways.
    This kit has a new aim though and that's to try and get a clean and smooth sea blue finish and try and get it somewhat interesting, which is a bit of a juxtaposition. Sea Blue shares a lot of properties with black, it's a paint that is very hard to get shading/fading that is noticeable, looks good, but not too overdone. One way of achieving this would be salt-chipping or stencils to get some randomised fading that looks akin to dirt or the effect of harsh sun, but neither apply to this Bearcat fresh from the factory in 1945.
    The reason for this is that I started making efforts on an FG-1D Corsair build I've had planned for a long time, and I'll probably get a build thread up in the future. I need to actually by the Tamiya kit I'll use, but I've painted up a resin cockpit and engine for the conversion. Following off the back of yet another Corsair build (which I need to get a headline article up for) I had a lot of trouble achieving a clean look, so fingers crossed no major painting incidents occur that make this currently smooth paintjob go sideways.
    Anyways, painting this Bearcat was simple. I ran out of primer so I first sprayed on MRP grey as a base, then went for tamiya black mixed with Mr Levelling Thinner for a smooth coat. I used a very light grey for a bit of pre-shading to see if it would do anything to the blue.
    The blue was applied and unsurpsingly the effect is barely visible. This is actually quite realistic but it does make the model look boring, so I'm back to that internal debate of realistic vs eye-catching. I masked off a few panels and sprayed them fully with the blue to give some more variation. All in all the paintjob is subtle, slightly noticeable in person and certainly very difficult to see on camera, but definitely seems appropriate for a clean build.
    With that I done we have a blue bear. I'm not really sure what scheme I'm going for, there's a few appropriate ones from 1945 but finding decals/masks seems unlikely so I'll probably have to try and find some generic mask sets and paint it myself.
    Also it seems those above us have fixed photo uploading, no issue today with photos I tried to previously upload a few days ago.
    Maybe it dropped off priority, but what a comeback, my friend @scalerambush!
    Your usual superlative paint job!
    It seems to get full priority right now, Harvey @scalerambush. What an amazing comeback.
    Thank you! Looks like this is going back on the shelf for a little while though, I think I might go for this Bearcat here
    Supposedly from VF-19 aboard USS Ranger in 1945, eitherway fits the scheme well. Issue is I now have to wait for generic lettering decals in the right size. I've seen some models do the lettering in yellow, which I'm not sure if is correct or not, so I'll try and get some research done though I imagine that is going to be hidden away in a book somewhere. It seems like the fuselage lettering is probably yellow (or, not white at least) though but not sure with the wings.
    Bearcats look cool in just about any paint scheme, Harvey (@scalerambush). It is amazing how hard it is to build a gear-up model with some of these kits. Looking forward to your paint scheme.
    Surely your research will pay off in determining the letters' color, my friend @scalerambush!
