Airfix 1/48th Curtiss Tomahawk Mk.II
Started by Julian Shawyer · 43 · 6 years ago · 1/48th scale, Airfix, Curtiss, RAF, Tomahawk
    John Healy said 6 years, 10 months ago:
    Looking good, Julian. I almost started mine this week, but elected to do the Airfix RAAF Meteor next.
    Julian Shawyer said 6 years, 10 months ago:
    Thank you John. Just wish I had a little more time at the moment.
    Good luck with your Meteor. It should look great in Australian markings. I'll keep an eye out for it.
    Julian Shawyer said 6 years, 9 months ago:
    Hello gentlemen, first of all, let me apologise for such a long delay since my last post.
    As you can see below, I've masked the undercarriage bay, and intend to spray the top coat tomorrow.
    After the top coat has a had a day or two to harden, I will polish the surface ready for weathering.
    Thank you for looking, Julian.
    I painted the lower wing surface with a coat of Mr Hobby Sky (H74). I'm not sure this is 100% correct, but had some at hand, so decided to use it as I wanted to progress the painting of the model.
    I let the paint harden before using a Black Flory Wash to highlight the panel lines.
    It was at this point I remembered that a section of the lower port wing is painted black!
    My fault for trying not stopping to think.
    The section that is going to be painted black, has a curve starting on the outboard edge of the undercarriage door, to the wing trailing edge. I've already enlarged the painting plan to full size so I can make a template for spraying the black section.
    The undercarriage bays have also been weathered at the same time as the wing.
    Thank you for looking.
    Louis Gardner said 6 years, 9 months ago:
    This Airfix P-40 build is fantastic Julian. I have a bunch of photos of a real one should you need any along the way.
    Thanks for the updates ! Looking good my friend .
    PS: If you look real close at this picture... you will see the little gap that is present when the flaps are raised. Another little subtle feature that Airfix got right.
    david leigh-smith said 6 years, 9 months ago:
    Julian, this is a great thread, I'm really enjoying checking in - sorry this is my first comment.
    Fabulous work and really interesting narrative - somehow I almost feel I'm part of the build which I think the best posts do (Louis is a master at this).
    One question; I'm just wondering if you stick by a particular 'mindset' when you are building - I'm always struck by how carefully crafted your models are. I really admire your style and wish I could capture some of that. Are you deliberately careful or is that just a natural thing?
    Thank you Louis, great photo. I see what you mean about the gap, thanks for pointing it out. Well, I've got that completely wrong! If I'm looking at the right gap, I've managed to close it right up! But that's a good shout for anyone else about to build this kit.
    What with that, and the lower surface colour, I've made a pigs ear out of it so far. Sorry about that fellow modellers.
    Stephen W Towle said 6 years, 9 months ago:
    Louis,
    This has been beaten to death on other forums, but, did you get a chance to photograph the Nun's Hat behind the engine cowling cooling flaps. Folks say that Airfix screwed the pooch on this but, given that they used a restored Long nosed P-40 as source material and when Curtiss went out of business they tossed all the drawings out... The folks who restored the air frame had to rely on either later model P-40's or look at the P-36 to get a serviceable replica.
    GARY DAILEY said 6 years, 9 months ago:
    P-40! what a sexy plane! My local IPMS group has been working on a group build and most of the folks have been using the Airfix kit...nice box of plastic to work with and their instructions have REALLY improved over the years. I built two of them, one using the old Monogram kit. One is the Parrot Head that raced at Reno and now resides in the Warhawk Museum in Idaho and the other is one of the Tuskegee airmen based in Italy in 1944...I did the research and fully documented both. The research is often as much fun as the build. These two offered cool color schemes and I LOVE to paint, so enjoyed them a lot. The Reno racer has an electric motor to make the prop spin and the background was inspired by those kinda-3-D pre-built display models that we used to see in stores when we were kids...oh, yeah, I'm STILL a kid... 🙂 ...home made decals for the Parrothead...done from photos...
    Hello David, thank you. I try to be careful, and build my models in subassemblies. I find it easier to build models like this. I find I don't have to mask as much which can make painting easier.
    I think I've made a mistake on this one with the main wing though.
    Great collection of P40s Gary.
    Having built this kit and being fortunate enough to see a real one all up close and personal, (even though it has been restored), I would venture to say that Airfix got it right.
    Stephen, it's funny you should mention the so called "Nun's Hat"... Why yes I did get some pictures of it. Here you go. This photo was taken from the Port side and is looking aft.
    This picture is looking forward, towards the coolers. This picture was taken from the Starboard side while I was crouched under the wing.
    This photo is self explanatory.
    as are these two...
    The wings are not flat on the underside as described by some. And the flaps do not close completely when raised. There is a gap along the trailing edge.
    One of the wheel wells showing the canvas cover...I think this is the Port side. If I remember correctly, I am looking towards the rear and the center of the plane when this picture was taken.
    You can see where the rubber from the tire has left a mark on the canvas. This is because the wheel was spinning as made contact with the liner. There is also a small wooden block present inside the well, that helps to act as a brake to help stop the wheel from turning as it is retracted. Keep in mind these tire and wheel assemblies are heavy. They also are spinning at speeds close to 100 MPH.
    Here's the proper orientation of the tail wheel doors. They are not positioned flat or at a 90 degree angle when open. It's more of a 45 degree as shown here.
    Here's the left wing root...
    and some pictures of the nose... which looks good to me too.
    Followed by a few pictures from the Starboard side...
    You will have to scribe on a trim tab that was somehow missed when Airfix made the kit molds. The tab details are strangely not molded on the Port side of the rudder... However they are present on the Starboard side of the kit part, but not on the Port side. That is strange indeed and an error, although small.
    This will take you all of 4 seconds to correct with a sharp blade. Meanwhile here's a picture of that spot too... The Port side rudder.
    Here's a few of the radiator / cooler details.
    Lastly here is the spinner...
    I hope these help to answer any questions that might be out there about the so called inconsistencies with this kit.
    For the money Airfix charges for this kit, and what you receive in turn, this is still the best kit on the market for the price as far as I am concerned.
    I personally like this kit, so much so that I went out and bought 3 more of them... making a total of 4 Airfix P-40B kits that I own now. I don't have investment stocks in Airfix, or a personal gain (or some kind of benefit) by commenting about the kit. I paid for my models using my own money too...
    But please don't take this directly as gospel from me... Check out the photos I have provided for you, and make up your own minds. Granted this "Real" plane was restored, and was rebuilt from a crashed example, but it was done correctly. If it wasn't, then good chances are the FAA wouldn't have granted it an airworthiness certificate.
    I put it to you this way. It's the best "restored" P-40B out there, (and it's possibly the only one in the world that is airworthy too).
    I hope this helps to answer some of the questions that were raised about this kit online ...
    I'm not trying to highjack your build log Julian, please forgive me if you think so.
    I like the work you have posted on your P-40 build. It looks fantastic to me. I will be looking forward to your future updates.
    Hi Louis, I don't think your trying to High jack the build. I really appreciate you and other modellers helping with advice and tips. The photos you posted are excellent, a big thank you for taking the time to post them. I've seen the superb P-40 you built, please feel free to post any photos of it on this build if you think it would help me or others.
    I've made an error on the wing trailing edge we're the flaps are concerned. Had I looked a bit harder at photos like yours, I would have got it right. Also, thank you for the photos of the Nun's Hat. I'd seen it mentioned, but didn't know what it was. Thanks again to everyone, and thanks for looking in.
    Daryl Huhtala said 6 years, 9 months ago:
    Love P-40s! I have 2 Airfix kits that I've yet to build but I've built all of the rest. #13 is Monogram, #48 is Trumpeter, #300 and #57 are Academy and Hobbycraft kits that were corrected using the Rick Barnds method; (#57 was flown by James Howard who later won the MoH in P-51B "Ding Hao")
    http://www.hyperscale.com/features/2000/p40brb_1.htm
    Thanks to Airfix the early P-40 is no longer such a daunting build.
    I'm sorry if this seems to be a hijacking but P-40s excite me and I'm watching your thread before I start into mine.
    Not a problem Daryl. Some fine looking P-40s you have there. I always find other modellers models interesting.
