Here's an update. I've been somewhat delayed this week by other things in my life, and model building has been one of those weeks when I make a small step forward and then have to wait for glue to dry before continuing . But I have gotten some things done.
First up, I primed the test mule black, gray, and white and then using a variety of colors, did some marbling on each primer section. I wanted to see how white would look over the different primers and marbling.
1. Dark Yellow over grey
2. No marbling
3. Red Brown
4. Dark Sea Grey
1. Dark yellow over white primer
2. Flat Earth
3. Neutral Grey
1. Dark yellow over black
2. Flat Earth
1. Medium blue over black
2. Flat Aluminum (this gave me all sorts of trouble when spraying)
3. No marbling
You'll probably notice that the marbling looks pretty bad. I was having a lot of trouble with my airbrush that day and I also couldn't seem to get my thinning ratios correct. But on the paint mule, this marbling is good enough for my test.
Then to continue with the airbrushing debacle, I sprayed Vallejo Insignia White over all of this marbling. I wanted to thin it out so I could sneak up on the coverage. But I ended up using far too much retarder and the paint took three days to get to the point where I could handle the model. Coverage was fine, and again, for the purposes of the test, good enough. I believe the dark sea grey marbling over the grey primer gives the best results but I will make the final decision when I get to actually painting (more on that in a moment).
After the difficulties with the Vallejo paint and airbrushing, I spent a day re-learning and practicing to make sure I get that right before committing to the Hudson. But before I can paint, I realized I had a bunch of small tasks to complete. Before I can paint the cowlings (and engine nacelles), I needed to add the intakes on the cowling and the lower nacelle. I added a small section of mesh screen to them as well. And the exhausts on the nacelles needed to be opened up at the aft end. I also made a preliminary attempt at reshaping the prop blades from the Ventura kit, but looking at them again, I realized I need to do another session before they look correct. So that still needs to be done.
1. First attempt at reshaping square props from Ventura. I need to do more reshaping closer to the hub to get these right.
2. Tubing for prop hub. I will cut these down
3. Intakes
4. Intakes with mesh screen
1. Open up exhaust aft end. This is about .75mm in height so it was tricky to do.
The cabin door is going to be open on this build and looking at photos, it appears that there are recesses in the fuselage for the hinges which are attached to the cabin door. So using a sharp X-acto blade I carefully removed a small amount of material for the recesses. The hinges were made from brass and CA glued to the door. I had to do several bends on them to get them to set correct. And I added a brass strip in the door opening to simulate the door landing. Fun stuff.
1. Using brass to make a door landing
1. Brass door landing
2. Brass hinges
3. Hinge recesses cut into fuselage sides
4. Still need to do some detailing on the door
Finally, you might notice that some of the liquid mask is coming loose from the cabin windows, so I am going to have to fix all of those before I paint. Such is the life of a model builder! 🙂
