Airfix 1/72 Lockheed Hudson I
Started by Carl Smoot · 272 · 9 months ago
    Great experimentation day on marbling/painting, my friend @clipper! Awesome job on both engines and door!
    Great to see all those various approaches on marbling and painting, Carl @clipper
    Looking forward to see how it will look in the end.
    George R Blair Jr said 10 months, 2 weeks ago:
    Hi Carl (@clipper): The shape of props has always been a mystery to me. The differences can be very subtle. I think the two biggest problems with reshaping props is getting a consistent shape and doing the work without snapping a prop blade off the hub. I am sure yours will come out well.
    Carl Smoot said 10 months, 2 weeks ago:
    Thanks Spiros (@fiveten), John (@johnb), and George (@gblair).
    I did a small bit of detailing on my True Details resin replacement wheels. These are not for a Hudson, but they are the same size if not slightly different. But considering the wrecked state of my kit wheels, these will look the part once painted. I believe the wire on the real wheels is safety wire on the lug nuts.
    The props have been reshaped. They aren't perfect, but they are acceptable. I still need to clean them up a bit. The props were reshaped by taking a Quickboost Catalina prop (which is too long, but the same type of prop) and laying it on a piece of Tamiya tape to get the outline. Then the tape template was cut out and shortened in length and used to scribe the outline of the shape on the Ventura props.
    Great progress, Carl @clipper
    Those propellors are a big improvement.
    Nice job on the wheels and awesome improvement on the props, my friend @clipper!
    Hi, Carl (@clipper): The wheels on my MPM-based models also have the square design on them. I was curious what they were, so I just did a little looking around on the internet. I couldn't find any close up photos of the wheels, but I found several distant photos where you could see the square on the hubs. I also found several photos where there was a smooth cover over the hub. I found a photo of some resin wheel for a 1/48 Hudson, and the design did indeed look like locking wires.
    I suspect that the lockwires would be an early casualty of a high cadence of operations during wartime. That could account for the smooth covers. Alternatively, they could be a design change from Lockheed. Hard to know for sure without spending a bunch of time researching it. Looking at that photo of the resin wheels, it appears that is the more likely arrangement of the wires (lug to lug). Oh well, live and learn.
    Carl Smoot said 10 months, 1 week ago:
    I finally got to the painting stage on the Hudson, at least the preliminary painting stage. I had two items which caused it to be delayed. The first was receipt of a new Ammo paint rack which triggered a desire to overhaul my paint storage at the work bench. My paint storage has been a thorn in my side for some time now and I kept coming up with all sorts of schemes to address it. Most were far too complicated (as usual for me), but I finally settled on one that checks off the boxes I had set for paint storage. It's not pretty, but it is functional and it has all my paint stored close at hand and in one place now.
    The second item delaying paint was actually adding the primer to the model. When I did this, I found all sorts of surface defects that had to be dealt with. I was close to the Shelf of Doom on this one, but I persevered and worked through the defects. All the pencil circled areas in the two photos below show what I had to deal with. Additionally, I made the mistake of having the airbrush too far from the model and the primer had a rough finish. That had to be smoothed out after fixing all the defects. All of this took several days.
    Today, I touched up the primer, got some smaller bits started in the painting process, and added the undercoat marbling for the white areas of the final paint. Some areas may have marbling that won't be white, but I didn't have the reference handy when I was painting and wanted to make sure I covered all possible areas. So over the next several days, I will be working through the various painting tasks.
    It's bloody cold here right now, and even in the house, we are having to wear hoodies (with the hoodies up), so it sort of puts a damper on motivation. But I want to get through this.
    Spiros Pendedekas said 10 months, 1 week ago:
    Excellent progress, my friend @clipper! Fixing the defects after priming might be a tedious job, holding you back from actual painting, but the result is really rewarding, ad is the case here, looking awesome.
    John vd Biggelaar said 10 months, 1 week ago:
    Great result, Carl @clipper
    I'm glad you persisted and prevented it from becoming a member of the SoD.
    Nice paint storage as well.
    George R Blair Jr said 10 months, 1 week ago:
    Looks awesome, Carl (@clipper). Glad you stuck with this one, I think it will look great when it is done. After all the challenges, I think I would finish it just out of spite. Your paint storage system is miles ahead of mine. I am just a little north of you, so we have also been "enjoying" the cold. Hopefully no problem with your pipes freezing. I guess we get a couple of days of relatively nice weather, and then more cold and a lot of rain. Looking forward to your painting of this model.
    Thanks Spiros (@fiveten), John (@johnb), and George (@gblair). I'm pretty sure I will be able to avoid the Shelf of Doom now, but I won't jinx myself by saying It can't happen. Painting so far has progressed okay. I've got the engines done, the propellers done, and the wheels done. The fuselage and cowlings have the white paint applied. Because it is Vallejo acrylic, I am giving it a full 24 hours to dry / cure before I mask it for the upper camouflage colors. I have had trouble with water based acrylics in the past being easily scraped so I may even clear coat the white before masking.
    Looking really good, Carl (@clipper). I have had Model Air occasionally rub off during handling, but I have never had a problem with Tamiya or AK Real Colors. I only use Model Air for small jobs, and I save the major painting for Tamiya or AK. I have some of the Gen 3 colors from AK, but I haven't tried them yet.
    Thanks George (@gblair). I have also been using Tamiya and AK colors and I agree they are super paints. One of the reasons I want to experiment with Vallejo is the color ranges that are available,but also because of they are safer to use. I have so far found them to be a bit more difficult to use when highly thinned, but this may also just be my airbrush technique which is still evolving. Regardless, water based or alcohol based, I find the use of acrylics to be far superior for me over my previous use of enamels.
