One caveat to this technique which I have already discovered and which precludes me from using it in my case this time is that you need to be able to sand both sides of the window and polish it. If not, then the results are about the same as using the Micro Kristal Klear. Because I had already added structure around the windows in the cabin, it was essentially impossible for me to get in there and sand and polish the insides. So I am using the Kristal Klear instead. I am not entirely happy with that decision, but I'll know next time that the windows should be installed before the structure, even if I use the kit windows.
The reason for the sanding is that, that UV resin is rather thick (at least the example I have) and it is rather hard to get it in there with enough glue to get the surface tension of the hole to come into play before you have more resin than is optimal. What ended up happening was I have a blob in the window that needs to be sanded down.
Unlike Kristal Klear (which shrinks as it dries), this glue cures immediately under UV light, so if there is excess, it stays that way and has to be sanded down. What I am going to do before I try this again on a future project is look for a more liquidy (thinner) gloss solution. You would still need it to be somewhat thick in order to use surface tension to hold it in the hole, but not as thick as my example is.
It also may just be because I was too heavy handed. This UV cured resin is a good product and has other uses in model building in addition to this technique.
Anyway, live and learn.
