Airfix 1/72 Lockheed Hudson I
Started by Carl Smoot · 272 · 9 months ago
    Spiros Pendedekas said 11 months, 2 weeks ago:
    Superb looking interior, my friend @clipper!
    Carl Smoot said 11 months, 2 weeks ago:
    Thanks John (@johnb) and Spiros (@fiveten). I have been having some painful back problems the last couple of days so work on the Hudson has temporarily slowed down. I am slowly working on improving the painting of the interior. My UV low viscosity resin was lost in transit so I have a replacement coming on Saturday. Until I get that done, I cannot close up the fuselage halves, so I am going to spend the time doing a bit more work on painting and weathering the interior.
    Once I get the fuselage halves together and the seams taken care of, I will be adding riveting and panel line detail to them. At some point I will get all this together so I can paint the exterior.
    Spiros Pendedekas said 11 months, 1 week ago:
    Wishing you getting well soon, my friend @clipper. I wonder how better your interior can get, since it already is absolutely perfect!
    John vd Biggelaar said 11 months, 1 week ago:
    Health is more important, Carl @clipper
    Hope you will recover soon from this back problems.
    I agree with Spiros @fiveten, no idea how to even further improve on this impressive interior.
    Carl Smoot said 11 months, 1 week ago:
    I think I am going to call it good enough on the interior work. I did add some additional weathering, made the instrument panel, and managed to break a small piece out of the forward nose when I popped out the windows (which were no good anyway. The damage is easy enough to fix and I will get to that shortly.
    I weathered the interior using a few different techniques. I am still trying to perfect my weathering so there is still more to learn and I can definitely see room for improvement. I painted the base coat, then used lightened and darkened shades of the base coat to highlight different parts of the interior, notably the spaces between the ribs and stringers. I highlighted the ribs and stringers by dry brushing with zinc chromate green. A pin wash was used (Tamiya Panel Liner - Dark Brown). I think I am going to move away from this and use oils from now on because the Tamiya wash is difficult to remove. Oils are more forgiving. I also think in the future, I am going to try wash colors more closely matched to the underlying color, rather than just arbitrarily using a dark brown.
    The low viscosity resin has still not arrived, so I will have to wait for that (to do the windows) before I can glue the interior in and close up the fuselage.
    So here are some shots of where it is at now.
    Your weathering skilles are very good, Carl @clipper
    This is a fine looking interior. Lots of details.
    Neil said 11 months, 1 week ago:
    Loving every minute reading about this build. Serves as an inspiration for my builds too. Love the interior details. Cheers.
    George R Blair Jr said 11 months, 1 week ago:
    Interior looks awesome, Carl (@clipper). All of that scratchbuilding really paid off. Well done.
    Erik Gjørup said 11 months, 1 week ago:
    Totally nice interior. Well done.
    Thanks John (@johnb), Neil (@neilpapermodel), George (@gblair), and Erik(@airbum). I'm glad I can contribute to the hobby in some fashion.
    I do hope that the resin for the windows will yield good results. I have two other fallback options if not. The first is trying clear epoxy resin, however, I am not sure if I can do this without leaks, so I would have to experiment first. The final fallback is to use the kit windows, but they would need to be sanded and polished individually, something I don't relish doing.
    While I wait for that resin to arrive, I think I will try to get some of the riveting on the fuselage done. Or perhaps, I will start working on the turret.
    Looking awesome, my friend @clipper!
    I really wish I hadn't used the kit windows, Carl (@clipper). I have noticed some uneven placement of the windows which is impossible to fix now. I was tempted to pop them out and use Krystal Klear, or something similar, but I discovered they are really solidly glued to the fuselage. It is good having the options that you do.
    George (@gblair), the UV cure resin might work to fill in those window gaps if you're careful in applying it.
    Today, I finally started installing the interior into the fuselage. I first wanted to get the windows in the cabin made using the low viscosity resin which showed up yesterday. Let me first discuss that.
    I reasoned that I could apply Scotch clear tape to the exterior of the fuselage over the windows and then back fill them from the inside using small amounts of the UV cure resin. My hope was that if I could apply a small amount of resin, then the windows would be flatter and less prone to distortion. By backfilling from the inside, I also ensured that they filled out the window openings (more on this in a moment).
    I tested one window doing this and it seemed to work okay. After it was cured, I applied Future acrylic to both sides (Pledge acrylic in some countries) and then let this dry. The windows have a nice glossy look to them and they did indeed fill out the test window opening flush with the exterior of the plane. However, there was still distortion. It appears that the windows are acting like a reverse magnifying glass, making objects further away look smaller.
    Okay, so mostly encouraged by this, I went ahead and did the rest of the windows. A couple of things happened here which should be noted for next time and for the unwary. Be sure to get rid of any and all bubbles, regardless of how small as they will still be there after curing. And in my case, in a couple of windows, they left a small unfilled area on the exterior.
    I think I could do better with a more precise means of applying the resin (perhaps a syringe through a needle blank). I was using a fine disposable brush. Also, because this was lower viscosity, it is important to make sure the window openings are level during the cure. Finally, to be absolutely sure, I cured these windows from both sides of the fuselage before removing the clear tape on the exterior.
    I used a UV light normally used to cure fingernails makeup (gloss resin) on people who go out for that sort of thing. I got this on Amazon for a small amount of money.
    In this photo, you can get a glimpse of the windows. What I am doing here is pre-installing the interior into one fuselage half. The fit is not perfect and I wanted to make sure it was properly installed on one side before gluing the fuselage halves together later.
    As a side note, you'll notice that the turret opening has the shaft installed. This is a simple "T" shaft which is supposed to trap the mounting between the turret lower half and the "T" shaft , so that the turret can spin. I glued this into position and when I install the turret in the future, I will glue it into whatever position I need for my diorama.
    Finally, I've done about 75% of the fuselage rescribing and riveting, leaving the tops and bottoms until after I fill in the seams.
    Awesome job on the windows, my friend @clipper! You are mastering the clear resin! Great overall progress, as well!
    Thanks Spiros (@fiveten). The UV resin has multiple uses. I suspect you could use it to do some simpler parts using molds. It's not visible in the photo, but one of the frames around a window at the front is broken out. When I added the resin, it flowed into this area and partially filled it in, so it will make repairing this easier later on.
    It does feel good to finally get past the scratchbuilding stage (even though there is more to come).
