Thank you gents.
@fiveten, hopefully I will get this one done before Eduard gets their S-199 out
@johnb, I usually start in the kindergarten when I have something I compare to other stuff, and also when I do not quite know what it is going to be in the end regarding markings and such.
@j-healy, The base kit is indeed not bad at all, and will build into a fully acceptable model – and if you add AM parts intended for the kit it is going to look great too.
@gblair, stay tuned. I have found it rather pleasing after a few resin conversions, and I could just have done some riveting and stuff on this one, but once the ball gets rolling. . . .
Another update here;
Too close, I think
Having had a fair share of armchair aviation, I find the intake is too close on the exhausts
I did address this in the kindergarten, but lets just re-visit. From pictures it is quite obvious there need to be just a fraction more space in this area
While I’m on a roll I think the intake to cool the sparkplugs is a bit basic too
I cut a large chunk of eduard cowling from the sawn off part
I cut a hole to insert the part, and dryfitted it.
Then just for the fun of it, laid it all out to check alignment and such
1. I think this bulge needs to move down too.
2. Exhaust opening moving down
Could be worse. I’ll glue that in and then some more filing to open up the hole for the exhausts
I am indeed having fun with this one, and off camera the wing is getting assembled – I also have to get started on the other half of the fuselage.
