Avro Anson of the Rhodesian Air Training Group
Started by Max Williams · 55 · 1 year ago · 1/48th scale, Airfix, RATG
    Max Williams said 1 year, 11 months ago:
    The vacuform Anson certainly is an interesting challenge, I’m making slow progress with it though. I think the detail on the Airfix kit will help me with the interior!
    Some primer work on the cockpit. I had to get a full understanding of how it all went together so included the side walls of the fuselage as well as the framing in a dry fit. And...shock horror...the first tiny "less than perfect" fit but not a game changer!
    There's a gap between the side walls and floor by the main spar, Airfix go to some length to warn about this fit:
    This is caused because the thicker part of the main spar extends a couple of mm too far outboard. Two solutions are possible; file the thicker part back to match the thinner outboard width or, as I'll do, widen that slot in the sidewall slightly.
    A couple of other views:, all dry fits and not corrected:
    The radio/wireless unit is nicely detailed with knobs, switches and dials, as was the instrument panel:
    but Airfix also provide decals for the faces of these units, which clearly are not going to fit over the "bumpy" surfaces:
    so I decided to sand off the face of the IP in order to use the decal, but the wireless unit I'll be hand painting. So having got all that clear in my head, time for primer:
    This is MRP Fine Black Primer. I like to prime in black because it enables me to gauge how much to build up the top coat of whatever colour I'm using to get the effect I want. That, hopefully will be tomorrow!
    With some corrections it will be fitting nicely, Max @maxw
    Great idea to use black primer.
    George R Blair Jr said 1 year, 11 months ago:
    Whichever correction you decided to use on the sidewalls worked great, Max (@maxw). Looking forward to your magic on the interior.
    Great that you found a solution for the fit issue, my friend @maxw! The interior looks fantastic!
    A few reference photos of the area that I’m working on, and towards:
    All of these from the Australian War Museum in Canberra, I took them when I went to Oz in 2019.
    On the model I’ve started making the internals look a bit worn and unloved:
    After a base coat of black I sprayed a loose coat of MRP interior green, the front section has received an oil wash comprising yellow ochre and Payne’s grey mixed with liquin, this medium producing a glaze. It dries slightly shiny so will need a final matt coat.
    Beautiful reference pictures and ditto result on the interior, Max @maxw
    Must have been great to wander around this Anson.
    Great pics, my friend @maxw! The inerior looks better and better!
    The paint and oil washes highlight the detail well, Max, (@maxw). Your reference photos really show how busy the cockpit was, as well as being easy to see with all of that glass.
    It could be a very tight fit at times!
    Indeed, my friend @maxw!
    Wow, what a tight fit, Max (@maxw). I hope everyone had a shower before they flew.
    Hmmm, showers? I offer the following from some recent research about a wartime RAF station:
    “From a (sadly) anonymous letter to the family from an airman at Balderton in 1944 -
    Just landed in last night and I must say that this must be the grimmest place in England. Dad says he slept up to the eyes in s--- in France, well we are living in it! The billets are corrugated iron Nissen huts, damp and cold, the lavatories are dry ones! which stink like blazes and to get a wash you have to walk across a couple of fields to the Sgts Mess (which is a fancy name for a wooden hut) and the food just about tops it all, the last place was supposed to be a Commando School but it was a paradise compared to this joint.”
    Thanks for posting this, my friend @maxw!
    More work on the Anson interior:
    and on the empennage, which is a very precise fit and allows for movement of the elevators!
    I designed masks for the front canopy, cut, applied and sprayed inside and out:
    More soon!
