During a conversation with Louis Gardner on pm about present and future modeling projects he told me he had bought quite a few of Eduards latest kits but had some doubts about how sensitive (lets call that way) these kits are to assemble.
I know that the majority of my fellow modelers here have one or two Eduard kits under their belt, as I do, and perhaps the build experience was good in some and not so good in others, but for those of you never cut the plastic in some of their newer kits I though posting my ongoing Focke-Wulf 190 A-6 would be a good example to show how good I think they are.
I’ve started this kit 3 or 4 days ago and since I wasn’t planning on posting it I took no pictures of the inner parts and the assembling of the fuselage and wings.
However as long as one takes care in getting the parts clean of any remains of the sprue gate, and do some dry fit test before glue, the result is a trouble free assembling, with very little putty needed.
I prefer to use liquid glue from Tamyia or similar and aplly it in steps, assuring that each area is align before moving forward. A good exemple where this method pays off is at gluing the fuselage halves and the following step, the mating of the wings to it. These are the most problematic areas regarding getting a good fit if one rushes to it.
Here’s how it stands earlier today
and after I started blackbasing the lot
The checkerboard nose will be fully painted because I don’t feel comfortable using decals over such unconforming surface as an aircraft nose is
Before starting masking the white to apply the black checkers, I opted to paint the I/D 04 yellow of the lower panels. This way I will permanently mask it until the completion of all painting stages
I find this the easiest method when that part comes moulded to the entire nose section.
On the other hand their “newer” 190 family in the form of the earlier versions (the short nose A-2/3/4) all come with a separate lower panel, allowing an easy way to paint them yellow, a cliche when it comes to Focke-Wulfs, thus avoiding the tedious tape masking.
Cheers!
