Checkerboard nose 190
Started by Pedro L. Rocha · 65 · 3 years ago · 1/48, Eduard Fw 190 A-6, JG.1
    Jim Harley said 3 years, 11 months ago:
    hands down my favorite 190 scheme...great job on the paintwork!
    Louis Gardner said 3 years, 11 months ago:
    Pedro,
    I used a small machinist metal measuring caliper and locked it down tight at a 1/4 inch wide setting. Then I laid the caliper over top a section of 1/4 inch wide tape and made a bunch of identical 1/48 inch squares.
    In 1/48 scale, this worked out to be a perfect 12 inch scale square at 1 to 1 real life size. I was lucky here, because once I started laying it out on the model, it turns out the ground crews most likely used the same 12 inch square measurement on the real plane.
    I used my good old eyeballs to match the little tape squares to an existing picture I had available of "Light House Louie". I started laying out the little squares of tape individually, and it looked like this:
    Then I sprayed the area black and it looked like this.
    Once I removed the tape, I realized that I had mixed my paint too thin. This allowed some of the black to seep under the tape, so I had to do a little bit of touch up work afterwards. It was not hard to touch up using a small paint brush.
    Granted these are flat panels, but it was a little tricky where the rudder / fin fillet mated against the fuselage, since this is a compound curve area.
    Hope this helps... 🙂
    Pedro L. Rocha said 3 years, 11 months ago:
    Nice Louis! Might try replicating your technique in some future Mustang project. Cheers!
    One last update before the whole nose is done (tomorrow I hope). The left side also completed, and much like the right side painting it needs some tuning, all manageable. This means that within a 3-4 days intermission the whole nose will be wrapped up
    Extremely well done! I like it a lot Pedro (@holzhamer).
    Thanks Erik @airbum, but I wouldn’t consider extremely well done 😉 a lot of tiny corrections to get those squares in tip top conditions and even then
    Spiros Pendedekas said 3 years, 11 months ago:
    Mmmmmmm, a nice chequered nose, Pedro @holzhamer!
    John vd Biggelaar said 3 years, 11 months ago:
    It looks great, Pedro, no doubt about it.
    Tom Cleaver said 3 years, 11 months ago:
    @holzhamer - from photos I have of the 78th FG P-47s getting their checkerboard noses, I would say what you have there is likely what the ground crews who painted the originals got. It looks very realistic and I for one would leave it as is.
    They weren't doing it for an IPMS Nats, you know. 🙂
    Again Spiros and John, thanks for your positive appreciation;-)
    Tom @tcinla - I have no doubt that ww2 ground crews from all armies had a lot less OCD than I do 🙂
    Ok so here’s the finished nose and the whole power egg
    and the view no allied bomber crew wanted to see, the head on shot
    Later today the 76 follows
    Cheers!
    Very nice touch-up Pedro (@holzhamer). This will be a hard act to follow!
    Erik @airbum, I hope this shows that any modeller with average skills (especially with a blade, ruler and tape) can reproduce checkers or cowl bands on his project. I know I’ll try to go back to masking tails when I build one of those MTO Mustangs
    Looks fantastic, Pedro @holzhamer!
    Looking forward to your 76!
    Just perfect, Pedro.
    You get me motivated to have one build myself.
    The model is now painted and with a gloss finish.
    There are a few nips in the camouflage I need to do, nothing serious obviously. Next comes exhaust stains and some weathering. I’ll take some photos of the undercarriage installation also, an area always a bit troublesome in a Focke-Wulf 190.
