    Looking nevertheless great, my friend @michaelt!
    Paint came out great, Michael (@michaelt). I have had a lot to trouble in the past covering my pre-shading with too much paint, so now I use post-shading almost exclusively.
    Painting looks great, Michael @michaelt
    I presume you are using Vallejo Model Air, although they say it is ready to paint directly from the airbrush, I'm still thinning this paint on a 1:1 ratio with thinner. I also add one drop of Vallejo flow improver to every five drops of paint. This gives an acceptable spray with the airbrush I'm using.
    Michael Turner said 2 years, 1 month ago:
    John (@johnb), I have been thinning the paint 3:2 paint:thinner. I don't have the flow improver so I might go get some. I still find that the green is more translucent than the other colours.
    George (@gblair), I used the dark grey to mid-shade (?) the light brown and then go over the light brown again.
    I have done this in the past - paint the camo colour, pre-shade and then go lightly again with the camo colour.
    I tried to lightly sand the brown wing tip where there was a little build-up of the paint but ended up scratching the paint off - evidently it doesn't like sanding. I repainted and the scratches are not too obvious - hopefully they will disappear further under a clear coat. Maybe I should use a primer with these paints in future.
    Looks excellent from here, my friend @michaelt! I m no acrylics guy, so, I cannot say anything more than I have heard that most acrylics are applied better over a coat of primer.
    G'day Spiros (@fiveten),
    I normally use Gunze acrylics and these go down fine without primer and can be sanded within reason.
    I know that many people prime their models - and I have bought some SMS black and white primers (I used the black to pre-shade) - but I am/have been too lazy to prime everything.
    Thanks for keeping tabs on this build (and others) and for the helpful comments, as always. :~)
    Perfect paintwork from what can be seen on the pictures, Michael @michaelt
    This triple color camouflage scheme looks great.
    The flow improver helps in such a way that the paint dries less quickly and therefore also prevents clogging of your airbrush.
    Acrylics are indeed scratch sensitive and it surely helps to apply a primer as a first layer.
    Sebastijan Videc said 2 years, 1 month ago:
    Nice job, Michael!
    I've been away to Oslo for an extended weekend and I am back with what I guess is my final in progress report in this thread.
    Added muddy pools and algae, further played with grass greens, chernozem browns, painted the exposed rocks, etc.
    G'day John (@johnb),
    Thanks, I like three-colour camouflage schemes.
    I must admit, after I had painted all three colours it reminded me of the Australian Army three-tone camo scheme of Cam Green, Tan, and Black that you can see on this Land Rover - and I had the same comment from a friend.
    Thanks too, Sebastijan(@inflames).
    You continue to impress your work on the base.
    The base looks amazing, my friend @inflames!
    Your base looks amazing, Sebastijan (@inflames). Will look great with your model.
    Your paint looks great, Michael (@michaelt), and does indeed look like Australian camo. I usually don't use primer unless I am using a light color like white, yellow, or red. I just used some ModelAir Ferrari Red on my current model and it was extremely translucent. I have never had any luck trying to sand acrylic paint. I usually end up trying to use some very fine sandpaper to blend the edge of the paint I removed and then repaint the area.
    Your base looks great, Sebastijan @inflames
    Thanks guys - just a work in progress sneak peek how she should look like in the end.
    G'day Sebastijan (@inflames),
    Gee, that looks good.
    What more is there to do?
    Looks great, my friend @inflames!
