Dauntless progress pics
Started by Ralph Clements · 17 · 10 years ago · Dauntless
    Ralph Clements said 10 years, 6 months ago:
    I started this Saturday, a Hasegawa SBD-4, trying to not rush it. Very soon I will face my first PE parts ever, the ammo belts which will have to go in when the cockpit gets all together. The instructions call for some colors I don't have, like 'burnt iron' so I am mixing my versions, also referring to some net pics I found of a museum specimen, added the little green & white bottle and hose to the pilots right based on that. And some knob colors and things.
    Just putting it out there since it seems i have reached a good progress marker, I took the photos just now to document progress since soon I will probably never see these parts again!
    Gregor d said 10 years, 6 months ago:
    So far so good Ralph. I look forward to seeing and hearing how you get on with PE. I've only ever used it sparingly in any of my builds with mixed success. Good luck!
    Rick Wilkes said 10 years, 6 months ago:
    Ralph, before you try painting photo etch parts, soak them in vinegar and/or gently scuff them with sandpaper. This gets rid any residual chemicals and provides some "tooth" so the paint will stay on better.
    Also any part that must be bent should be heated to "red hot" then allowed to cool naturally to remove the temper from the metal which makes them easier to bend and hold new shapes.
    Be careful when heating parts with an open flame since it is possible to burn up/ melt small parts.
    And as always be careful not to burn yourself or others, breath the fumes, set the workshop on fire, closed course, professional driver, you mileage may vary etc...
    Gregor, I am glad to know I am not the only person in the modeler world who may not be on board with the PE stuff yet...
    Rick thanks for the tips - I had already dipped these two tiny parts in white vinegar for about 10 seconds and set them aside to dry when I wrote this, but did not know about or think of heating them like you describe, which of course makes sense.
    I'll be careful and I'm sure my mileage will vary, I realize its a 'closed course, professional driver ' thing!
    AL HOFFMAN said 10 years, 6 months ago:
    Another little tip: when cutting the PE loose back it with tape or you could get plenty of mileage with it.
    Seamus Boughe said 10 years, 6 months ago:
    Ralph, if the PE does not work out for you or you want to try something a bit easier, go to a Wal-Mart or auto supply store and buy some small "Zip-Ties". If you look closely at a zip-tie, it resembles belt ammunition inside of a feed chute. Cut it to length and paint it. As the zip-tie is plastic, it is very flexible and can be bent. It can also be glued with CA cement. I used this technique in a 1/48 B-25 and a 1/72 B-26 and the results were stellar.
    Cheers
    Seamus.
    Thanks Seamus, I'll keep that in mind if I botch the PE belts. I'll give the PE a try as I figure they are a good practice before the rather intimidating and intricate dive brake PE parts.
    First ever PE by me went in last night, the two ammo belts. I could have done better on smoothly bending them and I could have done better on painting them (they are tiny, oh so tiny...) and I could have done better on installing them if my wife hadn't come in right in the middle of the crucial super glue moment to start talking about stuff...
    ...but all in all I am pleased with the result, they are the best looking ammo belts I have ever done...which ain't saying much... but is true!
    Next the dive brakes, oh gee, so many little PE parts, I will need to set aside a whole day and send the wife and daughter to the mall or something for them...
    Ralph Clements said 10 years, 5 months ago:
    Update on PE - well I started the dive brakes last night...there are 3 assemblies, left, center and right. My thinking was center is least visible and simplest, so I started with that, knowing not to expect a real beautiful result. I was right about the result, but the intimidation factor is greatly reduced as I contemplate the left and right assemblies - painting that center assembly will help cover flaws too I hope...after I get all 3 assemblies done I may post a photo of them if I can do the other two well enough that I am not embarrassed!
    Gregor d said 10 years, 5 months ago:
    Good going Ralph, i'd be interested to see your results as i've got a few PE sets for some of my older stash kits, and have been putting them off because of the "intimidation" factor. What sort of adhesive are you using to secure the PE?
    Its called Locktite Gel Control, a 'superglue', CA type. It doesn't set too quick, and gives me a minute or two to fiddle with the parts and adjust their placement, these parts are so tiny, fiddling with them is required. I drop a drop of that glue on my board, then take a toothpick and get about 1/4 drop, or less, on it and apply.
    Ken Patterson said 10 years, 5 months ago:
    Great start on the Dauntless
    Ok - go easy on a PE first timer here - hopefully the paint will cover these kind of beat looking dive flaps and improve the looks - glad to be done. I don't know if I got any better but it's practice for the even more intimidating Helldiver which has lots more PE...
    Each of these left/right lower flap assemblies has 12 parts, lt/rt uppers has 11 and the center lower flap (at bottom in image) has 15...
    I had to have some ice cream after this...
    Well, I say well done Ralph! I've seen similar PE for landing flaps on 1/48 fighters such as the Hurricane and Spitfire. Looks like a good job to me.
    AL HOFFMAN said 10 years, 5 months ago:
    Your doing good work here Ralph. I might have to try the ice cream reward when something goes well.
