Turnin’n bur. . . no wait
thatll be turning and turning – decided to improve the wheels and propellers
I just discovered khee kha’s amazing conversion for the Vazar Turbo Otter, and has entered a dialog with Lars on a set of props for the Twin Otter – but that may take a few days to be a new AM kit, and so attention turns to the turning propellers – that are supposed to stand still. And as mentioned in the CAF build, they have to be feathered when on ground.
To start with, here are all the efforts of the day;
All laid out for comparison
The blades are made from a piece of evergreen, with the major filing and carving done first to the whole set (8 blades as most likely I will need spares)
From the left; original, hub, new blade, and two rough blades.
And then the turning wheels got the center drilled out, a brass tube installed and then some curing time.
The tubing will need trimming, and a plastic inner will be made for the rim.
Finally I added a lot of lead to the nose. It seems a bit heavy, but rather a gram too heavy.
And some more filing on the blades will take place while the glue cures in the nose. . .
Feel free to comment – your input is what makes it worth posting here on this great site!
