Eduard Sopwith Camel, 1/48. Camel & Co.
Started by Harvey R. · 52 · 2 years ago · Camel, Eduard, First World War, RAF, RFC, sopwith, Sopwith Camel, WWI
    The blue looks fantastic, Harvey @scalerambush
    Other paintwork as well.
    Decalling approach will be easier this way indeed.
    Tom Cleaver said 2 years, 7 months ago:
    That blue looks good. Both of these look good.
    That whole blather about peeling the decals is so much @#$%$##$$@!. Just use Micro-sol and they go down like normal decals and look fine. They'd look better if they'd stayed with the Italians, but this is OK
    Harvey R. said 2 years, 7 months ago:
    Thank you all!
    Sure am wishing they stayed with good ol Cartograf.
    Decal Fun
    So, a few more decals were 'sorted'. The upper wing is mostly fine, some tears over at the B and some tiny ignorable bits elsewhere.
    I did have big old tear on that right decal, but after being annoyed at the underside I thought 'expletive, you can drown' and put a load of Micro Set (not Sol) on the half taken up film, and when I came back later it actually fixed the issue. So, that's something to keep in mind on the other camel at least.
    The underside? Well, let's just look at the results.
    Yeah, lots of rips, lots of tears. Not sure why this one has taken it so much worse, bad luck or bad skill? Perhaps I only gave the underside one gloss coat and forgot to give it a second? Either way I'll have some. Fun fixing that mess later, after more clear coats of course.
    So what have we learnt? Removable film isn't reliable, but we knew that already. We can fix them if we drown the decal with setter solution if we see a rip, which is handy but I wish I thought of that before resigning myself to the fate of the underside. Personally, I think that the decals just don't particularly like raised surfaces. Aside from the left fuselage B, the majority of the fuselage issues are around the raised areas. The wings, of course, are full of raised decals. Maybe its just bad luck but I didn't have these issues with the Spitfire build.
    Aluminium and Wood Work
    In other, less frustrating news, I was about to lay down decals on the fuselage when I remembered I needed to actually finish painting it. So I masked off the metal section at the front (plus the cowl) and painted it in MRP White Aluminium.
    Once this dried, I masked and painted the wood. I would have used Tamiya XF-10 flat brown but I used the last of it on the brown camel, so I mixed up XF-64 Red Brown, MRP Black and a tad of MRP red to make a colour roughly similar (of note is that Tamiya's XF-10 is darker, and actually a little bit more red, than XF-64).
    I used this as a base and then got the MIG oilbrusher dark brown out and applied it with a sponge to make streaks, then using a small flat brush I brushed across the surface too. From a quick jump into the Google images it seems quite a few Camels that popped up have the wood grain facing horizontal quite often, so I did that, though I'm sure many had vertical grain.
    And finally, more decal fun. The wings got the start of the roundels which will hopefully work far better this time, fingers crossed. At least this kite doesn't have a lot of decals to contend with, just a serial, the roundels and then finally a couple of markings near the fuel port.
    I've also started on the prop by painting XF-59, but realised it would be easier to do the painted sections of the wood prop first which the instructions of this and WNW say is a light grey. I'm half tempted to give the blue one a blue prop, can't prove me wrong very easily can ya! We shall see.
    Wonderful modeling skills, my friend @scalerambush! Pity the decals do not co-operate.
    Great progress, Harvey @scalerambush
    Indeed a pity about those decals.
    Thank you two! Thankfully, better success with Suds. A fair bit has been done since last!
    More Decals
    Not a lot of decals for the blue one, this time I went for the kill and used Mr. Mark Setter, and Mr. Mark Softener. I even went out and got some Tamiya Mark Fit strong.
    And it worked, the film was harder to get to but no issues with the decals this time thankfully. Most even looked fine with the film, though the roundel on the wing looked weird over the aileron and the serials really showed the thick film quite a lot.
    With that, I built the undercarriage. It's not perfect and needs touch ups, but it begins to make the aircraft look right. I also got round to fixing those broken decals on the brown camel with the airbrush and regular brush.
    Struts and Assembly
    Next up was to think about turning our monoplane into a biplane. The lower wings that were dry fitted previously were glued in, and then those struts done at the very beginning were added.
    For the brown camel I began to prepare for the dreaded stage of rigging. Rigging wire was dipped into superglue, then put into the moulded holes mostly on the lower wing. A few wires were added to the upper wing. I then began my first attempt of assembling the upper wing to the model.
    This didn't go too well. Let's look at why. On previous WWI models I've done I put some glue on the upper wing in each of the strut locations, then using a box to help align everything I try to put every strut into the upper wing at once, applying pressure whilst they dry before adding a weight (in this case, paint pots) to keep it down whilst it dries for a while.
    This caused a lot of issues, mostly with the wing struts not fully sinking into the holes in the upper wing. This resulted in the wing being very weak. Eventually I got it to work, but it took a lot of effort.
    Annoyed with this, I tried a different method immediately with the blue camel. For this one, I started by gluing the fuselage struts on, weighing them down to and letting it dry solid. About an hour later, I glued the wing struts on. This resulted in a far better and stronger join, and is definitely the better way of doing it.
    I think a possible reason for trouble is the dihedral on the lower wing, if both wings were flat it may be better to do all struts at the same.
    An Entry to Rigging
    This is where the fun begins. Oh boy.
    Actually, it's not been too bad. Tedious? Yes. Slow? Yes. Difficult? Not really so far, just a couple of wires that really didn't want to stick.
    With all the wires for the wings mostly on the lower wing, I then stretched the wire and held it in place with tape whilst I let it glue onto the upper wing.
    So far the wings are done, but some struts over the fuselage are needing doing. They should join together in a cross with a brace in the centre, but the plastic piece is horribly slip moulded and I'm not sure it would even really work out since it isn't hollow. I may ignore this piece.
    I also need to do the tail, and the various control wires.
    Superb progress, my friend @scalerambush! Great that you found your way with the decals. Loved reading your evolving methods of attaching the top wing. Both Camels look wonderful.
    Beautifully done, Harvey @scalerambush
    Maybe I missed it, but did you protrude the rigging wire through the upperwing? I do see tape on top of that wing so looks like the wire goes entirely through that wing.
    I haven't made any changes to the kit, so no wire going through the wing though I imagine since the holes/indents are already there you could easily drill through with a small bit, which probably isn't a bad idea now you mention it.
    I did it all separate though, I just used tape to help stretch out the wire and this sometimes ended up being taped on the other side. I've done almost all the rigging on this Camel now and the upper wing has it's control cables done, but they're separate strings the way I've done it.
    If you make the wires for the cross brace four separate pieces (you kind of have to anyway if you look at the different angles they're supposed to be) you can glue them to that central piece and have all look right.
    Finishing Touches
    Funny how things work out, the blue camel was the one I was excited about the most but ended up going ahead and mostly rapping up the brown one.
    Since the last update I got more work done with the rigging. Again, not a hugely difficult task I found, but very tedious.
    The engine was finished up, the pin is 2mm but the rods I ordered were taking a while to arrive so I used 3mm rods I already and made the hole in the fuselage bigger. The result is it doesn't quite spin freely, but it does move around without issue when pushed and most importantly doesn't fall off the aircraft. With that done the Cowling was added, and the guns.
    Regarding the cross rigging on the struts near the guns, I tried to make my own little piece to mimick the part Eduard provided which was had a huge slip in it, but I couldn't quite get it right. In the end I resorted to tying the cross rigging with a third piece that I taped to the upper wing, and then gluing it in the roughly right angle. I may go back and either see if there's an aftermarket option for this piece or try and make my own again at some point.
    Finally I added some weathering, not a lot mind you but some dirt around the skid and tail and some oils from the leaky engine. You can sometimes see a big black mark near the fuselage on the wings and its hard to tell whether that is actually an oil stain, a shadow or just weirdness from a 1917/18 photograph but either way I went the route of treating it as the build up of castor oil stains.
    If you wanted to make this plane go even further, you could always add a some repaired fabric and such as the pilot was noted as 'coming back shot to ribbons nearly every time he went out', but that's for another modeler to do not me!
    Finally I added the windshield, unmasked the wing inspection windows, and added the Aldis gunsight.
    And with that I present the shelf worthy Camel, until I decide the best approach about that brace if I do bother trying it.
    Regarding the other camel, I'm going to slowly work away at the rigging rather than going full focus on it over the next few days. In the meantime I have a Zero I've started on, and am trying to work a good way to create decent bullet holes in the clear pieces...
    Anyways, until the next update!
    This is a huge WOW, Harvey @scalerambush
    Everything is detailed to the max.
    Your paintwork, weathering, detailing is true craftsmanship.
    Thank you very much! The best thing is that even with the rigging, it was probably less frustrating the build than my last WWI kits. This could be a decent first step into WWI modelling, especially if you forgo the rigging for the first attempt, but as said even with the rigging it was more the time it took rather than the difficulty of it.
    Definitely a huge Wow! @scalerambush. This is a really nice result you have here.
