Flashback 1/48 Miles Magister
Started by George R Blair Jr · 49 · 2 years ago · 1/48, Flashback, LF Models, Miles Magister, RAF, trainer, WW2
    George R Blair Jr said 2 years ago:
    As usual, I was looking for information for another build, and found a photo of another plane I might like to build. The photo was of a Miles Magister that had a really cool paint scheme: half camo and half trainer yellow. I knew nothing about the Magister, so I did a little research into the aircraft. The Miles M.14 Magister, nicknamed the "Maggie", was produced for the RAF as a basic trainer from 1937 to 1941. The production run was 1203 aircraft. Designed to fulfill the elementary trainer role, it was eventually used in 16 primary flight schools as well as the Central Flying School. In 1940, 15 Maggies were fitted with bomb racks to determine if the plane could be used as a light bomber. The experiments showed that the Magister was not really suited to the bomber role. The Maggie was used throughout the war as an elementary trainer. Following the war, all of the Magisters were sold to 17 different countries, as well as to civilians.
    I began to search for a kit that I could build and came across one from Flashback, a company I had never heard of. I found some online build reviews that indicated that this was a pretty good short-run kit. One review even indicated this was an Eduard kit, but I suspect this confusion was because the photoetch in the kit was produced by Eduard. My search on Ebay found this kit, as well as several by Special Hobby. The Flashback kit was much less expensive than those from Special Hobby, so I got the Flashback kit for less than $20. According to Scalemates, the Flashback kit was originally released in 2001, and then was later released in 2 different versions by Special Hobby. I am glad I didn't buy the Special Hobby versions which cost a lot more.
    The kit is relatively detailed and includes plastic parts and a nice set of photoetch from Eduard. The only downside to this kit is that the wings and horizontal stabilizers attach with a butt joint, not my favorite but I will deal with it. I also found a nice set of decals from LF Models that includes the paint scheme that I wanted.
    The build has been relatively stress-free, so far. I wanted to open up one of the entrance doors on the right side of the cockpit, so I carefully cut the door out for the rear cockpit with a razor saw. The raised lines on the inside of the cockpit which outlined the entrance door didn't match the resulting cutout, so I sanded away the raised lines and replaced them with some fine plastic strip. I sanded away a lot of the thickness of the door so that it would be more scale-like, then added some thin strips for internal structure, as well as a locking bar that hopefully matches online photos of the door.
    When I assembled the wing halves, I discovered that the halves on one of the wings didn't match in length. The top of the wing was about 1.5 millimeters longer than the lower half. Hopefully everything will work out when I try to glue the wings to the fuselage.
    That's about it for now. I am moving fairly slow on this kit to avoid doing anything dumb with this limited run model. Closing the fuselage is next, followed by a few rounds of putty, sand, repeat. Cheers.
    10 additional images. Click to enlarge.
    Tom Cleaver said 2 years ago:
    Yes indeed, this does make up into a very nice little model. You are well on the way.
    Mine is straight out of the box.
    George Williams said 2 years ago:
    Looks pretty neat so far, George @gblair.
    Hi, Tom (@tcinla). I read your review on this model. I think you are right that it can be built in just a few hours, but I suspect mine will take a little longer.
    Thanks, George (@chinesegeorge). Seems OK so far. We'll see how it come out.
    Yet another great entry and equally great progress, my friend @gblair! Nice idea to open the entry hatch. Great IP and cockpit in general. Looking forward to it!
    Thanks, Spiros (@fiveten). It is moving fairly quickly. The paint scheme is the payoff on this kit.
    What a great choice, George @gblair
    Your usual research is defintely helping in understanding this aircraft.
    Your start on the interior is already amazing.
    Erik Gjørup said 2 years ago:
    I always enjoy these small planes. Strapped in on this build too @gblair.
    Thanks, John (@johnb). Interior went together quickly. Now, on to the wings and stabilizers.
    Thanks, Erik (@airbum). After my last planes, this one seems really small, even in 1/48. It is similar to when I was flying T-37s in the Air Force. I think it was the only plane in the Air Force you could step into without a ladder.
    I did several rounds of fill, sand, and repeat today. I like to get the fuselage, wings, and other parts all nice and smooth before I glue them to each other. I can't count the times that I glued all these parts together, only to discover that I created some really difficult sanding and finishing situations. Tomorrow I hope to glue everything together and get things ready for some paint.
    Looking good after the filling and sanding session, my friend @gblair!
    Looking smooth all over, George @gblair
    Thanks, Spiros (@fiveten) and John (@johnb). I woke up early this morning and attached one wing and prepped the rest of the parts for assembly. Pictures soon.
    Looking forward to the pics, my friend @gblair!
    @gblair, one of the advantages of waking up early, more modelling time, George.
